Author Topic: Amarok wheel options  (Read 1223 times)
Offline RGolf
« on: May 15, 2014, 04:19:03 pm »
Hi all,
What options are there for decent wheels for the Amarok, have one ordered for a new work vehicle arriving next week but the wheel options were limited so just have standard ones coming, boring at 17"....... is a work ute though
If anyone has anything let me know.
Ta
Offline hagan
    • H Dot Shots
Re: Amarok wheel options
« Reply #1 on: May 15, 2014, 04:56:43 pm »
The internets says land rover wheels will fit, but the centre bore might not be the same... Adapter rings maybe needed?
Some cheap 20s on TM
http://www.trademe.co.nz/729774141
Swaps for an S2K?
Offline tintinz
« Reply #2 on: June 05, 2014, 09:49:29 am »
I have highline Amarok and the if you go to www.hyperdrive.co.nz and click on wheels and select the following PCD "5x120" you will see all the wheels available for the Amarok. Just be cautious that even though PCD fits for the Amarok you will need to ensure the load rating is suitable for the Amarok. In saying this the following wheels are good for the Amarok KMC slides, KMC rockstars, Niche Milan, TSW bardo, TSW brooklands, TSW Rockinghams, Niche Verona to name a few.
If there are any Amarok owners on here with spare set of Aldos with tyres they would like to rent out to me as I need to swap my current Durbans to get painted but cannot afford to be without my vehicle please send me a PM
cheers
Tin
Offline subieboy
« Reply #3 on: July 08, 2014, 08:45:23 pm »
While at Bridgestone I fitted a brand new Amarok with some aftermarket Steelies like these:
YHI: http://yhi.co.nz/wheels/?Brand=Steel
Rough cost was $80 per rim plus tyres. (if you bail up someone like Tonys Tyre you could get them for a set of four plus Deuler tyres for under $1200.00 fitted)
