01e final drive knowledge
Started by MarkB5Audi, September 08, 2014, 09:47:03 PM
MarkB5Audi
Hello I have a 01e g box, I am trying to find out what the drive ratio is so I can find a s4 or tiptronic rear diff with prop shaft to sute the 01e I have, looked on Google no confirmed codes I have a few numbers, can any 1 help please? ??
A4 B5 q + s4 AEB:VR6 few new parts still not there.(Turbo) vr6 swap
Stanceking
1983 500sec
MarkB5Audi
Theres heeps
Middle section 01e 301 211c
End section 01e 301 231
Underneath 3075899EDU
On middle side section 10AEK-Z
Stanceking
Its an edu, used in the 2.7tt a6 and s4. Its 4.11 so you will need to change your rear diff as the 1.8t have a 3.89
1983 500sec
MarkB5Audi
Nice would the tiptronic a4 b5 work?? Will it be the same strength as the s4 b5 unit???
Stanceking
Quote from: Markt28Audi on September 09, 2014, 02:41:18 PM
If it's a 4.11 then sure. They are all the same strength.
1983 500sec
MarkB5Audi
Cool the strength was my main issue top man thank you have a good day im off to find a rear diff lllolll
MarkB5Audi
Hay now that I have the tiptronic rear diff on the way. Would my o1a prop shaft fit/work with the 4.11 ratio?? Its just an extending arm right???
MarkB5Audi
Stanceking
Yes you can just swap the nose over, what's the code of the new diff?
1983 500sec
MarkB5Audi
Stanceking
1983 500sec
MarkB5Audi
Hay just havi g a bit of trouble getting the link to the selector shaft and gearbox linkage
Is there suposed to be a bush or something to pack out the housing?? Really sloppy
