Mk3 brake upgrade
Started by Stanceking, February 12, 2015, 09:50:53 PM
Stanceking
Whats the options for an easy brake upgrade on a 5x100 car? Needs to fit under 16" wheels
1983 500sec
Pidge
Assuming it's a gti/vr6? If so you'll have 288mm discs
First steps would be braided brake hoses, good fluid and fast road/track pads.
TT 225bhp 312mm disc is an awesome upgrade but you need 17" wheels to clear them.
Same story with LCR brembo callipers.
HTH, Pidge
Looking for another Mk1 or Mk2
1999 VW Polo 6n oem+ (Current)
1980 VW Mk1 golf - bare shell rebuild (UK)
2006 VW Fox (UK)
1984 VW Mk2 golf Type 19 x2 (UK)
2000 VW Lupo (UK)
Filx
You can fit 312s under 16"s depending on the wheel design. I had 312s under 16x8 Speedlines Corse no problem.
I agree though some decent pads, fluid and brake lines is the easiest upgrade with 288s and probably fine for most situations. If not enough then 312 and correct calliper carrier is next simple upgrade.
Pidge
#3
 Beaten too it by Flix!  :P
Had done some more searching and as Flix says the TT 312 disc will go under certain 16s offset dependent.
2006 VW Fox (UK)
2000 VW Lupo (UK)
Stanceking
What calipers are used with the 312?
My wheels are speedlines 16x7.5 et35
1983 500sec
mark2 golf
Its the same caliper just different carriers from memory.
89 mk2 1.8t
97 mk3 gti 1.8t
90 190e 2.6
17 Amarok v6
09 golf gti
Pidge
Yep. As above. Use your current calliper a with the 312mm carriers and discs
2006 VW Fox (UK)
2000 VW Lupo (UK)
