Author Topic: **** Tuning Guide for Audi B5 S4 ****  (Read 7622 times)
Offline nogmeg
« on: February 19, 2015, 09:30:33 pm »
Tuning Guide for Audi 2.7 V6 Bi-Turbo 30 Valve. Engine codes: AGB, AZB
Factory Power: 261 hp   Torque: 400 Nm at 1,850 rpm
Hopefully this post can be refined by other members and we get a good overview of parts available for B5 S4’s
and some unbiased info pros & cons and prices.
Here is a rough guide to the stages Things like suspension, intercoolers, etc… can be done whenever.
Stage 1
ECU
Stage 2
ECU, cat back exhaust, downpipes, diverter valves
Stage 3
Turbo, proper fuelling, Stage 3 ECU
Turbos Available for B5 S4                    hp____________$NZD
034 Single turbo kit                           hp____________$4,378.00
Pro:
Cons:
Borg Wagner OEM RS4 K04                440hp____________$2,649.99
Pros:Easy install, Quick spool
Cons: max hp 440 hp
Frankenturbo K04                                    ____________$1,799.00
Pros: Cheap K04 alternative, bolt on
Cons: poor quality, eBay
Borg Wagner OEM RS6                             ____________ $5,769.92?
Pros: Non hybrid, top end power, higher rpm power, bolt on
Cons: More lag than K04, expensive
JHM RS6-R Hybrids                   600hp+____________$2,495.95
Pros: Quick spool, more low end power, Bolt on
Cons:
Loba LO530                              530hp+____________$3,226.49?
Is this still available?
Pros:
Cons:
Loba 600                                  600hp+____________$5,499.99
Pros: Like RS6-R
Cons:
Loba LO650                              650hp+____________$
Pros:
Cons:
Loba LO700                              700hp+____________$4,707.04?
Pros: Massive hp
Cons:
Loba LO750                              750hp+____________$5,999.99
Pros: Massive hp
Cons:
TiAl R520                                      520hp____________$
TiAl S605.2                                 605hp____________$3,514.64
Pros: Like RS6-R
Cons:
TiAl Alpha R770                         770hp+____________$5,162.17
Pros: Massive hp
Cons More lag than S605.2
Garrett GT25R 54                                  ____________$
Pros: Massive hp
Cons: Lot of custom work to fit
Garrett GT28R 60                                  ____________$
Pros: Massive hp
Garrett GT28 71R                  600-700hp____________$
Pros: Massive hp
Cons: Need displacement of 3.0L to work well, lot of custom work to fit
TTE700                                                ____________$
Pros: RS6 K04 OEM modified using Borg Wagner parts, Massive hp
Cons: Expensive
Other things to consider with a stage 3 tune.
Lots of other brands out there, these a just a few I chose to list.
Interior
VEI systems boost gauge
Air fuel ratio gauge.
Engine
JE 82.5mm or Mahle 81.5mm Bore 9.0:1 CR Pistons
034Motorsport Coated Rod bearings
034Motorsport Coated Main Bearings
Loba sport camshafts
ECS Lightweight pulley kit
Supertech intake valves, Supertech exhaust valves,
Supertech high rate valve springs & Titanium Retainers
Turbos/Exhaust
TiAl 44mm wastegates
Forge 710N diverter valves.
034Motorsport Downpipes with external dumps
Remove cats, 3.0”-3.5” exhaust. (APR, Milltek, 034, JHM, AWE, SSAC, Borla, Neuspeed, Techtonics, ASP, Custom)
Fuelling
034Motorsport Stage 3 ECU,
Bosch Drop-In 044 Fuel Pump Upgrade Kit,
034Motorsport 2.7T Billet Fuel rail kit,
034Motorsport Silicone RS4 MAF Hose,
034Motorsport 85mm Hitachi 2.7T MAF housing & sensor,
Bosch EV14 550cc Fuel Injectors, EV1-EV14 Fuel Injector Connector Adapters,
RS4 Fuel Injector Adapters,
Bosch F5DPOR Platinum Iridium Spark Plugs.
Intake
ER, AMD or AWE intercoolers
ER Carbon fiber intake shrouds,
JHM or AWE Single front mount intercooler
034Motorsport RS4 Inlet Pipe Set with Silicone Couplers,
RS4 Intake manifold & RS4 75mm throttle body,
034Motorsport or VAST 10mm Phenolic Intake Manifold Spacers,
Loba or VAST Port polished exhaust manifold,
ECS Carbon fibre RS4 Y-pipe (gold wrap),
034Motorsport or APR 2.7T stainless steel Bi-Pipe (gold wrap)
034 Silicone RS4 Throttle body adaptor,
034Motorsport X34 Carbon fibre Cold Air Intake.
Chassis/Drivetrain
JHM solid short-throw shift kit, (cheap eBay kits not recommended)
Vast OR JHM Stage 3 ceramic clutch,
ECS Aluminium flywheel 9 lb,
034Motorsport track density engine mounts,
034Motorsport track density transmission mounts,
034Motorsport Snub mount and bracket,
AWE or Autospeed drivetrain stabiliser,
Apikol Rear differential mount.
Suspension/Brakes/Wheels
Adjustable Coil-overs, H&R, Bilstein, KW,
ECS Rear heavy duty sway bars,
Density Line adjustable front upper control arms,
Adjustable rear upper control arms.
AP Racing 13” 4-piston big brake kit
Porsche cayenne/touareg 6 pot brembo calipers (JHM do a kit)
Brembo big brake kit upgrade
Stoptech big brake kit
Wilwood big brake kit
« Last Edit: February 20, 2015, 08:13:29 pm by nogmeg »
98 Audi S4, 96 Alfa Romeo 155 D2, 97 Alfa Romeo 155 TS
Offline nogmeg
Re: **** Tuning Guide for Audi B5 S4 ****
« Reply #1 on: February 19, 2015, 09:31:06 pm »
reserved
« Reply #2 on: February 20, 2015, 09:30:06 am »
Stock motor is good till about 500hp if you can keep the EGT's low.
At K04 power levels you will want to look into an updated clutch kit. In the region of $700-1000US.
Fueling kit will cost as much as your turbo kit.
Depending on turbo selection, will be the deciding factor on software to run.
Brake upgrade you can install the cayenne/touareg 6 pot brembo calipers. With a few options on discs.
On many turbo kit 500hp+ cons will be rebuilt bottom end.
Will add as I get more time.
Mk3 12v VR6 Variant
« Reply #3 on: February 20, 2015, 11:03:01 am »
What about the single turbo conversions, 034 was offering one from memory? Seemed like a lower cost and simpler option as you only have to buy one turbo.
Offline nogmeg
« Reply #4 on: February 20, 2015, 07:13:30 pm »
^^ good stuff, post some more details on brand of single turbo if you can. i'll take a look into that too.
I'll add those brake options, and try list all the brands of clutches and flywheels.
« Reply #6 on: February 21, 2015, 02:20:07 pm »
These guys do some nice goodies at very competitive prices: http://sillyrabbitmotorsport.com
K24 RS6 hybrids $2k US
K04 RS4 hybrids $1.8k US
Well worth considering. Their side mount inter coolers are supposed to work very well.
« Reply #7 on: February 22, 2015, 06:24:02 pm »
This is worth a read too:
http://www.myaudis4.com/philosophy/
The guy has done a bunch of stuff and he's documented it very well.
Offline nogmeg
« Reply #8 on: February 22, 2015, 08:00:58 pm »
sweet, I might make that post below my first one full of links to sites like that guys..
