Author Topic: Audi A3 Concert Radio  (Read 853 times)
Offline Helgz1
« on: February 25, 2015, 03:26:46 pm »
Hey there
Have a 2004 Audi A3 2.0T with the concert sound system, it has band expander but now seems to fade in and out regularly on FM, I have pulled it out to check if Band exp loose but doesn't seem to be, so thinking it could be the aerial itself? Any clues or anyone had similar issue? Really like the system so not keen to replace it :)
Online ziptie.nz
Re: Audi A3 Concert Radio
« Reply #1 on: February 25, 2015, 08:17:24 pm »
is it a double din unit. i have a Symphony 2+ that will go straight in if you have a double din centre.
what will be happening is that your Aerial won't be getting amplified voltage up to it. due to the band expander being in the way, you can fix it but in most instances its better just to find and install a Unit that can work without band expanders.
MK2 GTI 16v, MK2 TDI - Rollin' Coal, Audi V8 Quattro, Audi 100 2.2 ee
