Audi 80/S2/RS2 door card refurbishment
Started by RS ZWEI, March 04, 2015, 02:19:33 PM
With the vinyl (not leather - cheap Audi!) lifting on the RS2 I decided it was time to get it sorted (I guess this would be the same as a 80 or S2). On my car it seems to have lifted where the pressure points are on the door - where your arms and hands press on them.
Anton has given me some tips so here I go . . .
I thought I would start with the rear door for two reasons.
1) It was in the worst condition
2) It had a smaller and more simple vinyl shape
Ive had one of the front door cards off before, and would say they are easier to remove than the rears.
Here are the screws you need to remove:
(screw behind the door pull/lever)
(screw holding the door pull/handle together) Which once removed reveals these two screws:
You then slide the door card up, not out. But you also have to disconnect the door pull/lever, speaker wires and window winder plugs.
Once the door card was off I removed off the carbon trim:
To remove it all I all you have to do is flick these sliders off:
I had an issue removing an aftermarket tweeter (in the factory location). I had to remove the tweeter from its housing out the front so I could access the screw so I remove the mount:
The next stage is to remove the vinyl by rolling it off, then I got a plastic scraper and a brush with stiff bristles:
I have to decide on what thickness foam to use. 5mm or 10mm?
weta.worker
Nice!
Mines in the process of getting the cards redone (I'm upgrading to leather).
Car is still about 1.5 weeks away (according to the shop)
+ another few days to go back to Powerhaus to get a warrant
:D
1994 RS2 GUARDS RED
2001 RS4 NOGARO BLUE
Stanceking
Id say 5mm would be thick enough, Ive still got to do this for both of my 80's so let me know what you use
1983 500sec
Quote from: Stanceking on March 04, 2015, 05:01:13 PM
I think Anton recommend 10mm as he used 5mm.
ranton-inc
#6
5mm is ample. I looked at the 10mm again.. its probably a bit too thick.
Also get your hands on some 3M High Strength 90
Its a spray contact adhesive that is super easy to work with and sticks like damn... its just expensive  but worth it.
Quote from: ranton-inc on March 05, 2015, 05:33:51 AM
I think you are right in regards to 5mm.
le mans
#8
Regarding your Q in the other thread, when my vinyl started lifted I glued it back down using F2 contact adhesive. Seems to be holding up ok.
Quote from: le mans on March 05, 2015, 08:19:10 AM
Regarding your Q in the other thread, when my vinyl started lifted I glued it back down using my contact adhesive. Seems to be holding up ok.
OK.
Its the foam that it breaking down rather than the vinyl lifting.
If its working for you thats cool.
le mans
Quote from: RS ZWEI on March 05, 2015, 08:25:47 AM
OK.
All good, just an alternative option if the foam is holding up ok.
Im going to use the 5mm foam. I kinda wonder 7.5mm would be best, though I dont think you can get it?
So I think Im going to glue the foam down first, want for it to set and then glue the vinyl down? What do you think?
#12
The next stage was to tape the area up better so I dont get any glue over spray.
The method is to spray the foam and seal it both sides. This was recommended on the can if the material is porous. You then let it set.
Next you spray both surfaces you are gluing together. But you let it sit and go to tack for between 5-10 mins. Then line it up and firmly push it together. You only really get one shot at this.
le mans
le mans
How is this holding up Nik? Have you had a go with the front door cards yet?
Quote from: le mans on June 28, 2016, 11:23:17 AM
Yeah, not that great. It started lifting around the edges.
le mans
That's a bummer. My repair isn't doing too well either. Might need to get it done professionally.
