Intermittent electric windows
Started by le mans, March 05, 2015, 11:44:11 AM
le mans
Ever since I bought the RS2 it's had an intermittent issue  whereby all electric windows/sunroof would stop working. It recently went from intermittent to permanent. So I finally got hunting around for a fix and found this thread: http://www.s2forum.com/forum/showthread.php?t=31479&page=2
I pulled the relay and popped it open. Sure enough it had a cracked solder joint exactly as shown in the thread above. Bit of heat with a soldering iron and joint is good again. Happily, the windows and sunroof are fully operational again!
Apologies for the fuzzy pic.
