Author Topic: 200 help please  (Read 2538 times)
Offline mark2 golf
200 help please
« on: July 21, 2015, 05:10:13 pm »
Hi have a 86 200 at work and it has come in with the flashing triangle brake pad warning light on the screen.
I have read it can be brought on by the front pad sensor. brake fluid level, PS fluid level for the booster and the pressure switch on the booster.
I have tested all these and all seems as it should be.
Is there some thing I am missing. I have looked on elsawin but it doesn't go back that far on my system.
Cheers Mark
89 mk2 1.8t
97 mk3 gti 1.8t
02 Allroad tdi
99 s430 merc
90 190e 2.6
Online Mike1410
Re: 200 help please
« Reply #1 on: July 21, 2015, 11:11:29 pm »
I would go with a fault in either the brake pad sensor wire (perished/broken/missing plastic coating on the wire or wire itself pinched/ trapped causing a short) or the sensor connector plug (loose/broken/dirty connector terminals). It's a fairly common issue on a number of VAG products, but not surprising really given how exposed to the elements the wires/sensors are.  That's always assuming of course that the pads themselves have enough material on them that the wear indicator metal strip embedded in the pad is still intact and not exposed at all.
Offline mark2 golf
Re: 200 help please
« Reply #2 on: July 22, 2015, 06:40:33 am »
The pad sensors have continuity through them. I have bridged the wires at the car side of the plug and it still stays on.
89 mk2 1.8t
97 mk3 gti 1.8t
02 Allroad tdi
99 s430 merc
90 190e 2.6
Offline Pushbutton_auto
Re: 200 help please
« Reply #3 on: August 11, 2015, 11:44:25 pm »
Brake light bulbs ?
Offline cs100
Re: 200 help please
« Reply #4 on: May 15, 2016, 05:27:42 am »
i had the same problem, ended up being the pressure sensor on the brake booster…make sure you pump the peddle 20 odd times to relieve the pressure b4 changing….
Offline Pristle
  • vyf ster
Re: 200 help please
« Reply #5 on: May 16, 2016, 12:55:01 am »
Check power steering fluid. Failing that, check the bomb.
Offline wilco
  • Ted the Mechanic
Re: 200 help please
« Reply #6 on: May 20, 2016, 07:21:25 pm »
It could be the bomb failing - not building or keeping enough pressure in the system. I've had enough 100's and 200's that pretty much all of them had that at some stage.
Offline cs100
Re: 200 help please
« Reply #7 on: October 05, 2016, 08:27:13 pm »
Try cleaning the strainer in the hydraulic fluid container.
As soon as I did this (last week) the light went out and the pump was a whole lot quieter when wheels on lock.
