0 Members and 4 Guests are viewing this topic.
brian
Quote from: RobClubley on February 10, 2018, 07:28:21 PM
I'm wondering the same. But then they have older vehicles in all the time so you'd think they'd be used to them.
I have bled the master yes. it has had a new one at some point, I think Steve replaced it sometime in the last few years, could be wrong there.
It feels a bit soft at the top of the pedal then lower down it bites much better. I'll get it to someone who knows what they're doing as I want this sorted :)
The reason I questioned this, my Lotus always failed the handbrake test until I thought of a cheat to pass , then it returned to normal......................they simply expected too much from it.............umbrella handbrake actuating  a tiny 1" square pads on the disc.
Prior to going to the testing station, I wound the adjusters up till the pads were dragging on the discs, went for the test and voila.
Škoda Fabia 1.0 TSI Race Blue
colingrant
On my UR (LHD) the feds complained about too much pedal travel. As the pedal height is adjustable I bought it up to the level of the clutch pedal. The Feds said this was much better. It's all in the mind isn't it. There was no change in braking ability.
VW'n
Your right in taking it to someone even if it's just to confirm that all is ok.
Brakes is not something you want to go wrong.
If all is ok then a temporary adjustments of the pedal to pass warrent might be in order.
87 Mk2 Golf silver (the toy)
95 mk3 gti rusty ABF (Sold)
86 Mk2 Golf red (sold)
89 Mk2 Golf blue (sold)
brian
Quote from: colingrant on February 11, 2018, 10:51:48 AM
As in my case, perceived feel
RobClubley
I'm taking it to the Toy Shop Wellington tomorrow night. They happen to be there late for a training session and John the owner has very kindly said I can drop Rusty off after rush hour. It's about a 20km drive. I've organised the Mrs as support vehicle and taxi home :D
Better put some fuel in!
slowburn
I have a couple of master cylinders laying around if you need one for a comparison or whatever....sounds like bull crap to me....jerks. the brakes in these things aren't the best by todays standards but they do work and will stop you.
99 B5 S4 Avant
85 coupe quattro
72 fiat 124 coupe
97 corolla wagon
RobClubley
Quote from: slowburn on February 11, 2018, 03:54:20 PM
I have a couple of master cylinders laying around if you need one for a comparison or whatever....sounds like bull s**t to me....jerks. the brakes in these things aren't the best by todays standards but they do work and will stop you.
Want to come and drive it, see how it feels compared to yours?
slowburn
99 B5 S4 Avant
85 coupe quattro
72 fiat 124 coupe
97 corolla wagon
RobClubley
Quote from: slowburn on February 11, 2018, 08:08:08 PM
sure, and vice versa?
That would be good. Only thing is it's going to The Toy Shop tomorrow :)
slowburn
99 B5 S4 Avant
85 coupe quattro
72 fiat 124 coupe
97 corolla wagon
RobClubley
Should be about 7pm. Got to get the train home then head back in after traffic dies down.
slowburn
can meet you there before I head over to the Wairarapa...no probs
99 B5 S4 Avant
85 coupe quattro
72 fiat 124 coupe
97 corolla wagon
RobClubley
Quote from: slowburn on February 11, 2018, 08:20:23 PM
Awesome. Will message you when we're on our way.
snowtyres
You may already have this link, if not I hope it helps
Brake bleeding sequence for RHD Audi ur-Quattros
http://audifans.com/mirror/www.isham-research.co.uk/quattro/brake_bleeding.html
RobClubley
Quote from: snowtyres on February 12, 2018, 04:40:44 PM
I have seen that yes, thanks.
This is also useful:
http://www.20v.org/brakprob.htm
And according to those tests it's definitely not the brake bomb at fault.
RobClubley
That was awesome! First drive on the motorway, doing the 20km to The Toy Shop Wellington.
Made a new friend at the petrol station. That will happen a lot I think.
And what's that in the background in pic 2? A Coupe quattro with properly working brakes, that's what.
RobClubley
By the way according to the trip computer I averaged 16.5mpg, which is 17.1l/100km.
What was the problem?  Air in the system?
RobClubley
Quote from: 80 Vert on February 12, 2018, 10:18:46 PM
Not sorted yet. Had a drive of Takas' CQ and his brakes are way better at the top end, mine has nothing until about 2/3 of the way down. Not confidence-inspiring.
Toyshop will sort it :D The front wheels were hot when I arrived so the brakes are definitely binding, so they're going to remove and service the calipers first and go from there.
RobClubley
This is the update from today:
There is a fluid leak at accumulator area which needs sorting.
Calipers seem OK.
They are going to take a look at master cylinder today.
The discs aren?t right. The pads don?t contact the full surface area.
Toy Shop supplied the discs and are going to resolve that issue. New discs will be a week, so Rusty will be sleeping there for a while.
I've asked for a price to change gearbox and rear diff fluids while it's there. I don't fancy doing those without a hoist.
