Horch
According to the part number it?s already been replaced with an exchange unit. Measure the spool end float to gauge wear.
1988 urquattro MB
1986 MB 300SL
1956 DKW RT250
2006 Vespa PX200
RobClubley
The head is out!
Almost all of the exhaust manifold studs were loose. I can't find any cracks in the exhaust manifold, which is good. It's pretty mucky and corroded inside.
Dropped the turbo off at Diesel and Turbo in Petone for them to check out.
le mans
Bullet proof! Nice work, very brave.
RobClubley
Dropped the turbo off today at a local specialist for assessment, and the head and exhaust manifold to another one.
The manifold is warped and has been leaking quite a bit. Will get that machined. Waiting for assessment on the other stuff.
Quote from: 80 Vert on January 13, 2019, 06:52:15 PM
I'd definitely rebuild that, I'd recommend Steve Murch but he's not usually so fast as he seems swamped most times.
x2 for Steve - if it needs to be done.
RobClubley
Head work that's being done:
Assessment from Diesel and Turbo in Petone:
The exhaust housing has a few cracks but it will go again.
Turbine shaft has been rubbing on heat shield and bearing housing is eroded. We are trying to find some part to repair.
RobClubley
Well I'm not getting my torque wrench in there!
Bumper off next then. And work out how to get around the welded-in metal front panel.
Audi do
Top job...
Nothing quite like putting stuff back together that is nice and clean and has been machined up etc.
RobClubley
Bumper off, and it seems the internet is wrong about the crank bolt being 24mm. I don't have a bigger socket, so need to get one. Guessing 26 or 27mm.
Also I painted some bits.
RobClubley
user2154
#1750
M18 which is 27mm socket if it is the same an AAN?
If it is the same then this BMW crank bolt may fit if you need one, thread FYI.
https://forums.quattroworld.com/s4s6/msgs/353053.phtml
You got the right head gasket? 7A bore is 0.5mm larger than 20vt so generic Victor Reinz head gasket may not fit (quite right), see thread FYI make up your own mind. **Sorry your engine is not 7A, I am completely wrong I think? Ignore the rest then..
https://forums.quattroworld.com/s4s6/msgs/356298.phtml
I have some spare gaskets from the Victor Reinz 5 cyl head gasket kit (which I just bought) which I think are for the 10 valve (well I don't know what they are for), exhaust and throttle body I think. Can let them go for cheap + shipping. Post pics if you need them and I will see what is spare in the kit.
RobClubley
Will check the gasket against the old one and make sure.
My new wastegate diaphragm arrived. Picking up the repaired turbo this morning.
RobClubley
Yeah that's not looking too healthy.
brian
You seem to be unearthing a lot of crud
Škoda Fabia 1.0 TSI Race Blue
user2154
#1754
I found these gaskets on the supercheap website which I think will fit the wastegate. They look similar to the 034motorsports wastegate gaskets, ie: without the fire ring that the OEM gasket has. Should have the car going next weekend so I will find out if they leak or not. Maybe gasket sealer will work if not. For $7 each worth a shot.
https://www.supercheapauto.co.nz/p/permaseal-efg-triumph/SPO6657136.html
https://store.034motorsport.com/gasket-audi-i5-wastegate-outlet-034motorsport.html
user2154
Where did all that oil come from, was the wastegate diaphragm torn? So you must have had a massive boost leak?
RobClubley
Quote from: user2154 on January 27, 2019, 09:36:44 PM
That's what I wondered too. It's more like oily rust than just oil. I got the wastegate tested and apparently it was leaking. Which is why I bought a new diaphragm.
RobClubley
Audi do
Quote from: RobClubley on January 21, 2019, 07:05:25 PM
Had a look at my engines crank bolt yesterday, KG turbo. Found it was a 27mm so likely yours is the same.
RobClubley
Yep mine is definitely 27mm.
The head is back!
