I re-checked the intake air temp sensor - wiring is good to the computer and showing 22 ohms across the terminals.
I also replaced the dodgy looking terminals to the throttle switch and checked continuity and operation of both switches.
Then I found this
http://www.audiurquattro.de/ecu/check.htmTo check the speed sensor, remove the plug from the ecu and connect an LED across terminals 11 and 24.Crank the engine over with the starter.
If the Led flickers on cranking the sensor AND wiring are good.
All good
Checking the reference sensor is similar. Connect the LED across
terminals 12 and 13 of the ecu connector. Crank the engine over, the led should flicker. If it doesn't, check the wiring.
This one didn't flicker.
Once I pulled it out it appeared the wiring was damaged on the sensor. So maybe this is the source of the problem.
