0 Members and 6 Guests are viewing this topic.
RobClubley
Quote from: dubstar on August 10, 2016, 07:04:33 PM
http://www.carcarpets.co.uk/audi-quattro---20v-2-door-carpet-set-1989-to-1991---blenheim-range-61757-p.asp
Brexit makes it cheap
Cheaper at least. But I'd rather get it done locally and guarantee fit. Plus get a local warranty. There's a place in Tawa called Kohl Road and Custom who have been around a while and do good work. They were talking about $650 ish to do all carpets including boot.
brian
The freight on a set of carpets would destroy the 'bargain' UK price being both bulky and heavy
Škoda Fabia 1.0 TSI Race Blue
Audidude
#682
Quote from: RobClubley on August 11, 2016, 10:49:10 AM
Let me know how you get on with the local re-make, Rob.
$650 sounds pretty good. The 20V floorpan is different to the MB and WR (as I discovered when I bought a set of mats from the UK!!)
My driver's carpet is toast.
Edit: just read my earlier post - seems I've repeated myself, but I'll leave it here -  #seniormoment
RobClubley
#683
Will let you know. I have a few more things to do before. I'd like to get the car driveable to get it down there.
Got the seatbelts on Friday so I decided to fit them today. I had to cut new holes in the rear shelf so they'd work properly - wondering if the GT had different holes to the quattro. I binned my original parcel shelf as it had big oval speaker holes in it, and this one was in way better condition. I thought they were identical, but apparently not.
The rear belts it came with - one is a Volvo one but looks identical to the other which has a VAG part number.
I took the tail lights out and put the seals in - not something to forget :)
I have working rear lights.
Brake lights, reverse, fogs and indicators don't appear to work though.
brian
A lot of NZ cars do not have working indicators :laugh:
Trofeo
Need the ignition on for those other lights to work, so a completely different circuit to the tail lights. Did you try the hazard lights?
RobClubley
Quote from: brian on August 14, 2016, 09:01:45 PM
True!
Quote from: Trofeo on August 14, 2016, 09:44:52 PM
That would explain it, I was too lazy to go back into the house and get the key.
I think the hazard relay is buggered - turn them on and I just get a buzzing noise. Haven't investigated that yet.
Audidude
Mostly BMWs....hey they always have right-of-way.
RobClubley
Tried again with the keys in. I get more tail lights, indicators light up but don't flash, need to check the relay.
Reverse lights and brake lights need sorting out.
And now the fuel pump isn't working and I need to move the car in a few days for new insulation to go in under the house :D
deedub
Quote from: RobClubley on August 17, 2016, 09:21:36 PM
Your indicator issue could be the hazard light switch rather than the relay.
RobClubley
I have a spare, will try it. I should have a spare relay too.
Rob, how does your wife take the project?
RobClubley
#692
Quote from: RS ZWEI on August 18, 2016, 10:14:50 AM
She tolerates it :) Mainly because she knows how much I love these cars.
She has realised how much it has cost so far though so now she's taking the "La la la not listening " approach to the budget.
Tempted to do that myself.
I ordered a set of tyres for the 18s from the local Bridgestone, as they have the monthly 30% off for buying four sale :)
Turned up this morning with the wheels and they said "Oh sorry we meant to call, they're on back order, no ETA."
Ah well I can wait. These wheel boxes have been in and out of the garage so many times!
schattenblau
RobClubley
Quote from: schattenblau on August 18, 2016, 01:02:57 PM
what tyres did you order rob ?
If I could get them they were Bridgestone MY02s. 215/40R18.
schattenblau
Take the opportunity to save for something a bit more special for the mighty q
;D
Filx
wilco
Rob your electrical stuff not quite working properly could be as simple as poor earth connections somewhere given there is now paint where previously was rust.  But you will have thought of that eh... :)   Especially the hazards..
RobClubley
Quote from: wilco on August 18, 2016, 09:36:50 PM
Yeah the thought had occurred. That's why I made a new earth connection to the rear lights from an earth point. It's going to be a matter of taking the time to check and trace everything.
I have four days to get it to start again so I can move it out of the way for the house insulation installers.
RobClubley
#699
Well the dash no longer flickers since I ran a new earth to the rear lights!
I re-fitted the door card on the driver's side after testing the window. I even got my daughter to help scrub it clean!
Back to the starting - I fixed the fuel pump - just a dodgy wire joint to the pump.
Still no start though.
Checked the wiring as best I could, looks okay I think. I even tried adding back the dodgy looking loop in the ignition wiring, no joy.
Tried the spare starter switch from the GT. Nope.
Found two blown fuses, changed them, no apparent difference.
But now the radiator fan runs all the time the ignition is on!
Two days to go!
Charging battery again just in case it's that. If not it might be time to investigate the starter itself.
