Author Topic: Build thread - Rob's Audi UR Quattro  (Read 125397 times)
1 Member and 1 Guest are viewing this topic.
  • Audi Owner!
« Reply #1320 on: January 22, 2018, 02:50:49 pm »
it's good they are removable
 ;D
:D
And.............paw prints..............that would drive me nuts
I know! Damn cat got herself locked in the garage for 24 hours.
Wheels off to bleed the brakes again.
Don't worry that's not where I jacked it
quattro project
Offline black16v
  • paul
« Reply #1321 on: January 22, 2018, 09:29:01 pm »
Hey Rob, maybe check the load adjusting valve on the rear axle. I had one that leaked from where the mechanical linkage went in and sucked in air. Took a while to find it. No signs of leaking and had to keep bleeding the brakes. Had to peel but the rubber cover to find the wet signs of leaking.
1988 MK II GTI 16V
  • Audi Owner!
« Reply #1322 on: January 22, 2018, 09:49:15 pm »
Will check everything again. There's no valve at the rear, just a union splitting the pipe to each rear wheel. That has all been replaced.
Didn't get the brakes bled today as I spent the rest of the day wallpapering the lounge. :D
I did fit my new HT leads though.
« Last Edit: January 23, 2018, 10:55:13 am by RobClubley »
quattro project
  • Audi Owner!
« Reply #1323 on: January 29, 2018, 11:25:18 am »
Brakes bled again and they feel much better, I think they're okay now. Brake light switch is intermittent, so I ordered a new one. Just the headlight to check out and it's time for another WoF.
quattro project
  • Audi Owner!
quattro project
  • Audi Owner!
« Reply #1325 on: January 31, 2018, 09:29:49 pm »
A shiny new brake light switch has fixed the intermittent brake lights. I can't see any sign whatsoever of water in the headlight. So I'll book in for a WoF re-test next week. First chance I'll get to drop it off.
quattro project
Offline slowburn
  • how many is too many?
« Reply #1326 on: January 31, 2018, 11:06:25 pm »
super easy to unclip the glass and have a nosey in there if you wanna be absolutely sure they don't kick you back on that...hate that kind crap
89 200 quattro exclusive(gone to a better place)
85 coupe GT
  • Audi Owner!
« Reply #1327 on: February 09, 2018, 02:13:09 pm »
WoF re-test tomorrow....
quattro project
Online brian
« Reply #1328 on: February 09, 2018, 02:17:56 pm »
Best of luck
MGF  V̶W̶ ̶P̶o̶l̶o̶ ̶1̶.̶6̶  Škoda Fabia 1.0 TSI
Offline WRURQ
« Reply #1329 on: February 09, 2018, 05:13:56 pm »
Good luck Rob 👍🏼
Offline FFS
« Reply #1330 on: February 09, 2018, 08:05:02 pm »
🤞Gonna be a pass surely. Good luck though!
Offline slowburn
« Reply #1331 on: February 10, 2018, 12:39:10 pm »
results???? 8)
85 coupe GT
  • Audi Owner!
« Reply #1332 on: February 10, 2018, 01:15:11 pm »
Sigh. He's still not happy with the brakes. So it's a fail. Going to take it to The Toy Shop Wellington I think, see what their opinion is. Just need to get it there outside of rush hour traffic.
quattro project
« Reply #1333 on: February 10, 2018, 01:20:48 pm »
  • Audi Owner!
« Reply #1334 on: February 10, 2018, 01:22:27 pm »
quattro project
  • Audi Owner!
« Reply #1335 on: February 10, 2018, 01:32:33 pm »
Cheeky snap in the driveway on the way home.
quattro project
« Reply #1336 on: February 10, 2018, 06:56:08 pm »
Online brian
« Reply #1337 on: February 10, 2018, 07:00:02 pm »
What is their problem with the brakes..................is it retardation or pedal feel?
Do you think that they are expecting an older vehicle to match 21st century responses?
« Reply #1338 on: February 10, 2018, 07:11:11 pm »
The pedal probably travels too far or is too soft.
Rob have you bled the master cylinder? It's pretty common for air to get trapped in the master cylinder and no matter what you do the brakes will feel crape till you get rid of that air.
With a car that has sat soo long I would have rebuilt or replaced the master.
  • Audi Owner!
« Reply #1339 on: February 10, 2018, 07:28:21 pm »
I'm wondering the same. But then they have older vehicles in all the time so you'd think they'd be used to them.
Rob have you bled the master cylinder? It's pretty common for air to get trapped in the master cylinder and no matter what you do the brakes will feel s**te till you get rid of that air.
I have bled the master yes. it has had a new one at some point, I think Steve replaced it sometime in the last few years, could be wrong there.
It feels a bit soft at the top of the pedal then lower down it bites much better. I'll get it to someone who knows what they're doing as I want this sorted :)
quattro project
