Author Topic: Build thread - Rob's Audi UR Quattro  (Read 185083 times)
« Reply #1800 on: April 02, 2019, 12:56:41 pm »
Get someone to tow the Quattro using the A4. Then you can sit in the UR and pretend that all is well in the world  8)
  • Audi Owner!
« Reply #1801 on: April 03, 2019, 10:48:41 am »
Making brrrm brrrm noises! :D
« Reply #1802 on: April 03, 2019, 12:00:11 pm »
Looks pretty good!
  • Audi Owner!
« Reply #1803 on: April 28, 2019, 08:23:31 pm »
Thanks to Wellington European for the loan of their smoke tester. It pointed me straight to the seal that I have totally left out. Not sure how that happened!
 It runs much better and will warm start. Got an exhaust leak at the waste gate and it's still dripping oil when warm, and there are a couple of heat shields rattling. So I have work to do.
https://www.facebook.com/ProjectRustyquattro/videos/680060922409742/
  • Audi Owner!
« Reply #1804 on: April 28, 2019, 08:34:12 pm »
Offline Audi do
« Reply #1805 on: May 04, 2019, 09:29:05 pm »
With all these troubles.......at least you have a ur quattro, how many people can say that?.
Sure beats working on some nondescript japanese car.
  • Audi Owner!
« Reply #1806 on: May 04, 2019, 09:34:37 pm »
Exactly! It is my dream car and I will drive it.
Though it was potentially getting sold recently as I've separated from my wife and we were splitting stuff.
Managed to sort it so I could hang onto the car.
« Reply #1807 on: May 06, 2019, 09:58:21 am »
That's never good news.  :(
Good thing she didn't get a grinder out and split the Audi down the middle.
When I was a kid, parent's of a mate of mine split up. She insisted that they get an even split....The dad was a tree feller.  He took a chainsaw to everything they owned and cut it all in half.
  • Audi Owner!
« Reply #1808 on: May 06, 2019, 10:02:51 am »
Oo that's a bit extreme. We have had a very amicable split, so nothing like that was happening.
But the split is part of the reason that things are moving so slowly with Rusty.
I fired it up this weekend and the metal shield between the block and the cam gear is rubbing on the gear. I tried to bend it a bit in place and made it worse, then my daughter lost a critical piece of Lego so I had to leave the car alone :D
Very tempted to just get it transported to Wellington European and get them to finish things off.
« Reply #1809 on: May 06, 2019, 11:28:50 am »
Maybe just time to let the dust settle so you can regain your mojo for the build.
Offline Audi do
« Reply #1810 on: May 29, 2019, 04:04:08 pm »
Well that's not so good Rob.
Glad you managed to hold onto the car.
  • Audi Owner!
« Reply #1811 on: May 29, 2019, 04:09:24 pm »
Still haven't really got anywhere and I need to. Got that heat shield bent back I think but now need to suss out the leaks.
  • Audi Owner!
« Reply #1812 on: May 30, 2019, 12:22:36 pm »
« Reply #1813 on: May 30, 2019, 02:14:31 pm »
working late into the night...
 :laugh:
  • Audi Owner!
« Reply #1814 on: June 03, 2019, 07:57:16 pm »
Backed Rusty out of the garage. This happened.
Not sure the water pump is even working properly. I drove down the street and back. Things are not right
I think it's time to get Rusty to Wellington European, and stop putting it off. Because I really don't want to pull it all apart again myself. But I don't think I can really afford that.
https://www.facebook.com/ProjectRustyquattro/videos/338270913523823/
I did give it a wash though.
Offline Pristle
  • vyf ster
« Reply #1815 on: June 04, 2019, 02:14:11 pm »
https://youtu.be/ld0Yp6rlEVE
Sorry Rob, but that sound way to smooth to be a 5-pot  8)
Offline snowtyres
  • 1990 urq RR, 1995 S2 Coupe
    • roof carrier systems
« Reply #1816 on: August 14, 2019, 10:10:43 pm »
hi Rob
we have not heard from you for a while...hope you and 'rusty' are ok
  • Audi Owner!
« Reply #1817 on: August 15, 2019, 04:19:39 pm »
hi Rob
Thanks, yes all is well, been concentrating on a new relationship and trying to get the house and my life under control :)
Finally took a few hours off work today and spent some of it starting to get back into Rusty.
First time I've touched Rusty in 3 months, apart from the odd pat on the rear as I passed :)
Pulled the secondary radiator out, will bypass it for now, run the engine and see if I can see exactly where the coolant leak is coming from. While I was in there I also changed the thermostat.
  • Audi Owner!
« Reply #1818 on: August 15, 2019, 10:00:59 pm »
I know I've been neglecting it recently but I love this thing and get a little thrill of excitement every time I see it.
« Last Edit: August 15, 2019, 10:02:43 pm by RobClubley »
« Reply #1819 on: August 16, 2019, 09:57:18 am »
And one day you will be able to drive it whenever you want!! And it won't leak or stall and the dash will work every time....... One day  ;D
