0 Members and 8 Guests are viewing this topic.
Quote from: RobClubley on October 19, 2020, 03:10:58 PM
I was in Ohakune this weekend so popped over to Smash Palace for a little pick over the Coupes they have there.
interesting tracking the final days of those coupes.
i saw them in 2016.
the grey one is new ?
slowburn
red one still have the smoked lights in your pics.....
This is one way to fix it...
Not that I'd do that of course.
Little school run test drive.
slowburn
wolfgang
1985 Audi urquattro
1980 VW Scirocco S
1987 VW Scirocco Scala
1967 Dodge Coronet
1984 Chevy Corvette
First drive!
Some random pics from around Wellington.
Lots still to sort out but I have a usable car now, and a baseline to go forwards.
Very happy indeed.
Hmm...
le mans
#1990
Well done Rob, and what a car it is!
Regarding the boost cut issue you?ve had I wonder if it could be something as simple as a damaged/crushed vacuum line going into the ECU? Whatever it is I suspect it?s one little thing causing it. Does the UR have a boost cut function based on a temperature input? It?s apparently quite a common problem in the slightly newer S2 era cars. MFTS sensor I think it?s called. Common to fail. Wish a new a bit more about the engine management on these awesome URs.
The ecu is pretty basic. I've replaced the vacuum lines, I do keep hearing a whistle, wondering if there's a small leak on boost.
There's an intake air temp sensor and engine speed sensor. If either is faulty it can cause this. The intake sensor seems okay and I've checked connectivity.
The other I haven't traced yet, connections to it seem okay.
What was the fix in the end? Relays?
le mans
Rob, requesting plug for the leather care product(s) you?re using. Your seats look lush.
Quote from: 80 Vert on October 31, 2020, 08:41:44 AM
Let's just say the light won't come on over 30kph any more.
Quote from: le mans on October 31, 2020, 10:49:26 AM
It was something with silicone in I think, I'll ask Kohl what they used.
black16v
Have you now got TWO engine oil pressure lights?   ;)
1988 MK II GTI 16V
I decline to answer on the grounds I may incriminate myself.
I re-checked the intake air temp sensor - wiring is good to the computer and showing 22 ohms across the terminals.
I also replaced the dodgy looking terminals to the throttle switch and checked continuity and operation of both switches.
Then I found this
http://www.audiurquattro.de/ecu/check.htm
To check the speed sensor, remove the plug from the ecu and connect an LED across terminals 11 and 24.Crank the engine over with the starter.
If the Led flickers on cranking the sensor AND wiring are good.
All good
Checking the reference sensor is similar. Connect the LED across
terminals 12 and 13 of the ecu connector. Crank the engine over, the led should flicker. If it doesn't, check the wiring.
This one didn't flicker.
Once I pulled it out it appeared the wiring was damaged on the sensor. So maybe this is the source of the problem.
