MkIV Wiring Gremlins
Started by bawked, August 19, 2015, 08:30:56 PM
bawked
I bought a Mk4 Golf R32
What is this thing on the dash? Is it a GPS receiver?
On leg of the wire is connected to this thing? Is this a ground?
This is the wire the GPS? unit, it is cut though so the unit isn't powered.
Then there is this orange wire from behind the light switch
This cable runs across under the the steering wheel, haven't traced where it goes.
Does anyone know what the unit on the dash is? Also what would the wire from the light switch be?
ranton-inc
You better sell it looks like you have an atomic bomb under the dash
bawked
Quote from: ranton-inc on August 19, 2015, 08:38:11 PM
But at least the remote activator has been cut!  :o
ranton-inc
Quote from: bawked on August 19, 2015, 08:45:51 PM
Lol
The thing on the dash will be a GPS satellite.
The wire off your headlight switch may have been a place for them to tap voltage off
Fizz
#4
It's the Navigation GPS Antenna for PANASONIC STRADA CN-NVD905U
bawked
Ok, so these things had nav units stock. The last owner had put a panasonic headunit in as a replacement, so it looks like I can rip all this wiring out.
Fizz
Quote from: bawked on August 20, 2015, 09:29:15 AM
No it would have been GPS unit for the Panasonic headunit not OEM.
