Author Topic: UrS6 turbo oil usage  (Read 1166 times)
Offline zeitgeist
« on: September 22, 2015, 03:37:19 pm »
My '94 S6 uses oil. It doesn't smoke unless perhaps under high boost but normal driving nothing to notice. It is the turbo, as the ducting beyond the turbo is all oily including pooled oil in the Michelin man hose.
What are my options for the turbo?
Been restoring a classic launch for the last year and a half, NOT KEEN to go for an expensive option for my measly turbo.
Cheers guys
Nathan
UrS6 6 speed
Offline 89 Coupe
Re: UrS6 turbo oil usage
« Reply #1 on: September 22, 2015, 05:30:19 pm »
I have noticed this problem in my S6 over the last 4 months also. Having the same symptoms as you are  ???
-Using oil
-Grey smoke for a few seconds after hard boost
-Oil in the intercooler pipes
Doesn't smoke on start up, only what appears to be a little condensation build up as is definitely water.. Doesn't smoke from normal driving as far as I know.
Could it be valve stems or turbo oil seals?
PCV valve has been replaced.
« Last Edit: September 23, 2015, 08:04:27 pm by 89 Coupe »
1991 BMW E34 535i
1989 Nissan Skyline R32
1993 Nissan Skyline R33 Coupe
1989 Audi Coupe Quattro
1996 Audi UrS6
1994 BMW E34 540i Touring
1994 Audi 80 Avant Quattro
Offline Lomax
  • Czech Republic
« Reply #2 on: October 04, 2015, 12:38:58 am »
same here, smoke and smell is much more obvious since i removed the cats
i suspect the turbo seals
1994 Audi UrS6 6-speed manual
2002 Audi Allroad 2.7T
1990 Mk2 Golf, 1994 UrS4, 1990 Audi 80 2.0E Manual, 1990 Audi 80 2.0E donor, 1991 Audi 90 2.3E, 1985 Toyota Corona
« Reply #3 on: October 04, 2015, 07:40:55 am »
I kind had this issue with the RS2 a few years ago. I thought it was the turbo but also got the valve guides done at the same time. Turns out it was the valve guides. Once this was done it didnt use any oil.
Offline zeitgeist
« Reply #4 on: October 06, 2015, 03:42:45 pm »
Although valve guides wouldnt go through the Michelin man hose and turbo outlet like mine....
UrS6 6 speed
Offline zeitgeist
« Reply #5 on: November 23, 2015, 12:12:32 pm »
Fingers crossed sorted, fitted a recon'd S2 turbo from Anton (cheers!). Can't induce smoke now, no other changes or increases in drivability.
Unsure if I will keep it or not, I still need a nice diesel 4wd- the Audi isn't the best for lugging boat gear
UrS6 6 speed
