4motionings R
Started by 4motioning, October 01, 2015, 06:20:30 PM
4motioning
Factory Specs
2011 MK6 Golf R (Jap import)
DSG
OEM 18"
OEM Euro Sports Recaro's
Jap spec RNS510 (removed)
Interior
Eonon GA5153F android HU
Extended DSG shifters
Dashcam wired with Eonon HU
500GB Music Harddrive w. modified glovebox housing
Removal of sunvisor airbag safety stickers
Modified OEM armrest cubby
Vagcom
Windows up/down with remote
Comfort blinker
Curtesy wiper activated
Emergency braking hazards enabled
Exterior
Numberplate backing mod and relocation
Vinyl Carbon fibre wrapped badges front and rear
Suspension
Adjustable 27mm swaybars front and rear (2way)
Okuyama underbody chassi bracing
Okuyama front strut brace
Front and rear subframe deadest kits (unknown brand)
Engine
Okoda Projects plasma direct coils
Soundaktor disable
Exhaust flapper disable
Volant CAI
Tarmac engineering heat shield
Modified OEM engine cover
42 Draft Designs 3' catless resonated downpipe
Stage 2 tune
Perfomance
~320hp (VAGCOM)
1/4 Mile: 13.6 (ran with stock tune and CAI)
Current projects
integration of OEM pop out reverse camera
DSG kickdown disable
Catback
6.6bar fuel filter
Future Projects
DSG tune
FMIC
HPFP
Stage2+
mk6 Golf R
03 Mk4 Golf V6 4Motion
very nice indeed,
Best choice in colour and interior.
Can't wait to see what's going to happen to this beastie.
slowmo
Very nice!  8)
Definitely the best colour! What are your plans for it?
Current: 2004 MK4 R32 3-door NZ New DBP
Past: 2010 MK6 GTI / 2013 Nissan Leaf LOL / 2007 B7 RS4 / 2006 MK5 R32 / 2005 MK5 GTI / 1998 MK4 GTI / 1997 B5 A4 MTM
4motioning
Stage 2+ xmas or next year then see how it goes.
For now I'm focusing on getting it looking right and preparing it for Stage 2.
I don't know a heap about the service history, and even though the stealership did a full engine + DSG service I hardly trust it.
I got screwed around with replacing the bald tyres the dealer had on it, otherwise it'd be rolling on something other than OEM by now.
mk6 Golf R
thomas.dq
2020 Suzuki V-Strom 1000
2017 Mitsubishi Outlander
2016 Nissan Leaf
1997 Mk3 Golf VR6
2010 Mk6 Golf GTI
4motioning
Catch up with the little things that ive been doing on my R.
Not long after i got picked it up i installed a eonon ga5153f head unit.
the rns510 was still in jap mode and i gave up trying to do anything with it and this one provides more features.
I also prefer it as i spend a bit of time playing around with androids, so it makes sense for me.
Even though it says that it will only support a smaller hard drive through the USB cable, i have been happily running a 500gb HD with all my music on it through the poweramp app.
Ive also installed another app, i forget the name but i think its something like RK303, that helps interface downloaded apps with the steering wheel controls.
And i have a GPS adapter cable to run the OEM GPS, but i think the supplied GPS receiver may actually work better, so may go back to that for a bit to see if the accuracy improves.
im still working on adapting the OEM reverse camera to the HU, that's my next project now that the parts have arrived.
I also found that the glare on the screen was at the perfect angle to be distracting as i drove, so i added some spacers to direct the screen towards the drivers side and its worked a treat.
mk6 Golf R
4motioning
while doing an oil change i noticed that my R came with some random Jap braces.
everywhere apart from a rear strut brace... not complaining...
Also has larger two way adjustable sway bars.
mk6 Golf R
4motioning
Had to get in there a vinyl up the emblems....
that one looks a bit rough, but i tidied it up after the pic.
i only had a sample piece of vinyl, so it was a bit of a stretch to make it fit
mk6 Golf R
4motioning
I was getting annoyed looking at the over sized jap license plate backing, so i modified that and re fitted my plates.
mk6 Golf R
4motioning
stupid japanese airbag warning stickers on my sun visors are no good, they gotta go!
after soaking the sticker with some alcohol swabs for some time, it lifts away leaving just the glue
i did use the alcohol swabs at first to try and remove the glue, but it was taking too long so i moved on to something a bit more potent
the scrubbing did stretch the visor material a bit, so i pulled out the old steam trick and retensioned the fabric.
mk6 Golf R
4motioning
bit of xmas coding.
Thanks to Scott for the vagcom
mk6 Golf R
Nice work,
What coding did you do on the mighty R?
4motioning
Quote from: GLIDN on January 06, 2016, 05:31:41 PM
Nice work,
Nothing super exciting, cleared the airbag light and modified all my convenience settings.
Basically went thru the popular vagcom tweaks from another forum and applied the ones i liked.
mk6 Golf R
4motioning
some updates...
so i guess almost a month ago now i had Arno do a carbon clean and replace my cam follower.
I've had the car coming up to a year now and have always been curious about how good/bad things could be, since its a jap import with no history.
anyhow, the pictures do the talking..
the one on the left is mine
needles to say, its running nice and smooth now  8)
mk6 Golf R
4motioning
And then this happened....
the kit from Tarmac came with the free heat shield.
mk6 Golf R
4motioning
does this count as 4x4'ing???
mk6 Golf R
HaNs
Did I see this in penrose about 6pm tonight? Or was it another 4x4 spec R?
4motioning
Quote from: HaNs on July 21, 2016, 10:42:44 PM
Wouldnt have been me.
mk6 Golf R
4motioning
mk6 Golf R
insane
how'd you get on with the new downpipe? Did you also flash it?
