Author Topic: Window goes down but not back up - Any ideas?  (Read 3812 times)
Offline Sully
« on: April 26, 2016, 02:31:00 pm »
Hey guys, just after a bit of help.
My rear left passenger window goes down with the button but not back up again (window has to be pulled back up). I can hear the motor working when pressing up and down on the button and the window can be pushed down at any time meaning the window isn't locking :(
Anyone have any ideas on what the problem might be?
I appreciate any advice.
Offline Pristle
  • vyf ster
Re: Window goes down but not back up - Any ideas?
« Reply #1 on: April 27, 2016, 12:24:19 am »
Sound like the regulator
« Reply #2 on: April 27, 2016, 12:46:25 pm »
This sounds to me like a MK3 typical problem.
Have you only tried using the button on the door? or have you also tried the button from the centre console in the front?
Do you experience the same issue.
If yes, then as Pristle has kindly pointed out, a new regulator or more likely the motor will need to be swapped out.
Mk3 12v VR6 Variant
Offline thomas.dq
  • They call me Thomas.
« Reply #3 on: April 27, 2016, 12:51:34 pm »
Pop the door card off the door and have a look if you can see anything obviously wrong in there.
IIRC, there are 3 screws in the handle on the door. Use a small flat head screw driver to pry off the front half of the handle (at the seam), then you can access the screws to pop the door card off.
1997 Mk3 Golf VR6
2010 Mk6 Golf GTI
Offline deedub
« Reply #4 on: April 27, 2016, 06:24:07 pm »
There is a ridiculous little piece of plastic on the regulator cable clamp thingy that breaks causing this issue. Blocks of wood hold up the window and keep the rain out  :P
« Last Edit: April 28, 2016, 11:11:31 pm by deedub »
Offline Sully
« Reply #5 on: April 28, 2016, 09:00:45 am »
Yea, using the center console has the same effect as using the door control.
Thanks for the advice guys, will open the door up and have a look this weekend. Got a feeling it might be to do with that the piece of plastic on the regulator cable clamp.
Will update with when I have found the issue  :D
Offline thomas.dq
« Reply #6 on: April 28, 2016, 07:24:32 pm »
I think I may have used cable ties when the little plastic thing broke on mine   :P
1997 Mk3 Golf VR6
2010 Mk6 Golf GTI
Offline Christian
« Reply #7 on: November 10, 2016, 08:43:40 pm »
Having the exact same problem, please update me on how you fixed it
Offline JEWDUS
« Reply #8 on: May 16, 2017, 08:07:52 pm »
Just picked up one of these, same problem here. Any tips? Gonna have a tinker around and see what happens of it.
