Author Topic: A3 04 sub frame engine mount.  (Read 633 times)
Offline abotha87
« on: June 04, 2016, 09:30:55 am »
HI
Hoping for some knowledge. My mechanic friend had a quick look at my car after I said I noticed a engine wobble feeling when I accelerate. Apparently my suffrage engine mount the rubber bit? Is cracked?
My question is this a huge fix? Or is there a way to just get a new bolt or some such?
Thanks
Ash.
Offline abotha87
Re: A3 04 sub frame engine mount.
« Reply #1 on: June 04, 2016, 04:17:19 pm »
Sub frame** engine mount*** auto correct grrr
« Reply #2 on: June 04, 2016, 05:25:32 pm »
They are easy to replace.
Offline abotha87
« Reply #3 on: June 05, 2016, 12:41:01 pm »
As in? Sorry I'm female and a little clueless. Is it an expensive fix? I've had so much work done on this bludy one, worse audi ive ever had. Door barrel replacement to car would stop locking by itself while running.... 575 for part alone then the Cambelt start of the year and then the water pump fkd out after 5 months and had to get a new one. So grrr.
« Reply #4 on: June 05, 2016, 01:29:41 pm »
Engine mounts are pretty easy to change.
The water pump should have been done at the same time as the cambelt. They are all maintenance items. The door locks could have easily been repaired. Pays to take the car to someone that knows what the are doing
