Author Topic: Auto to manual conversion  (Read 4636 times)
Offline 00quattro00
« on: June 28, 2016, 09:53:51 pm »
Auto to manual conversion requires a bit of cutting and welding
Auto
Manual
Part number 443803961E. Can be bought from audi tradition
Re: Auto to manual conversion
« Reply #1 on: June 28, 2016, 11:25:02 pm »
Good info.
01 B5 RS4, 95 P1 RS2, 00 B5 S4 Sedan facelift, 01 B5 A4 1.8TQ Avant Le Mans
« Reply #2 on: June 29, 2016, 06:47:55 am »
What car is this?
Offline 00quattro00
« Reply #3 on: June 29, 2016, 07:21:43 am »
What car is this?
Urs6 although it applies to all c4 and c3 cars incl the v8
Offline user2154
« Reply #4 on: April 17, 2017, 04:41:10 pm »
you got the trans installed? What gearbox did you use? What rear diff? Did you find these in NZ?
« Last Edit: April 17, 2017, 05:22:32 pm by user2154 »
Offline 00quattro00
« Reply #5 on: April 17, 2017, 09:21:25 pm »
Gearbox is in, i was doing an engine swap at the same time as I originally bought it for the engine. Im using an ENV gearbox from a v6 tdi. It has good long ratios and is 3.89 so I dont have to change the rear diff. Gearbox and associated parts came from europe
Offline user2154
« Reply #6 on: April 18, 2017, 08:35:06 am »
Nice, I always thought swapping diff was a stupid idea when many Audi gear boxes are 3.89, this solution is better as long as ratios are nice and gearbox is strong enough.
Offline 00quattro00
« Reply #7 on: April 18, 2017, 12:09:48 pm »
Swapping to 4.11 is no big deal, I've got a stack of diffs
Offline user2154
« Reply #8 on: April 19, 2017, 07:32:37 pm »
so why may I ask did you go with this particular gearbox?
Offline 00quattro00
« Reply #9 on: April 19, 2017, 07:41:48 pm »
Ratios suited and it has the oil pump on it
Offline user2154
« Reply #10 on: April 20, 2017, 06:46:31 pm »
Will be keen to hear about the results when done, car will fly. I quite like the auto trans though, there must be some later model auto / tiptronic boxes that would also fit if mine goes kaput one day, ECU communication may be an issue though.
Offline user2154
« Reply #11 on: November 11, 2018, 01:04:28 pm »
Never heard back about this? How did it go?
Did you change the front tripod CV's to the ball (Rzeppa) type or did the originals fit?
Did the main driveshaft (Cardan shaft) fit or did you use one of a different length?
« Last Edit: November 11, 2018, 01:35:16 pm by user2154 »
