Idle issue
Started by bugn8r, October 03, 2016, 06:09:02 PM
bugn8r
Hey guys, thought I'd post up here and see if anyone has had a similar issue.
When I start the car it revs fine and continues to idle perfectly if I leave it sitting. When leaving the drive it starts to climb and by the time I hit the lights down the road it's revving at close on 2k. If after 5 minutes of driving I turn the car off and leave it sitting for 10 minutes or so the car will start and idle perfectly however if I leave it for a couple of hours it will have the same issue start over again and rev up.
If I don't stop and drive for 15 minutes or so the idle will drop also.
Any ideas before I start testing things?
fabgeii
what engine? any modifications? sounds like a crank shaft speed sensor on the top of my head but could be multiple reasons
sifty
Is it a K-Jet or carby?
It'd be worth checking the O rings on the idle screw. Mine was doing similar things and that was the cause.
bugn8r
K jet, EJ motor! Will do cheers. Yea the car is far from original so has a mix of stock and other VW hoses/connections.
