Author Topic: Mk1 Scirocco parts required  (Read 1792 times)
Offline dave
Re: Mk1 Scirocco parts required
« Reply #20 on: March 25, 2018, 08:36:52 pm »
How did you go about restoring the dash? Looks good
Offline wolfgang
« Reply #21 on: March 25, 2018, 10:09:13 pm »
Took me almost a week to do the job, i removed the dash from the car and then ground and cut all the loose plastic and flattened all the cracks.
Then I filled the missing pieces with fibreglass matting and epoxy filler, sand and fill about 4 times until it looked smooth.
Then sprayed the dash with bedliner and lightly sanded it back to get the dimple effect of the original material and then sprayed it again with satin black. I still have to add the brushed silver strip.
It is by no means perfect and if you stand close you will notice that it's not original but it certainly a lot cheaper that get it recovered from scratch.
« Last Edit: March 25, 2018, 10:13:21 pm by wolfgang »
1985 Audi urquattro
1980 VW Scirocco S
1987 VW Scirocco Scala
1967 Dodge Coronet
1984 Chevy Corvette
