Removing the reverse fog light
Started by Nz_gti, January 02, 2017, 12:46:52 PM
Nz_gti
Hi, bit of a novice question or two.
I want to replace the fog light on the back to a second reverse light.
Is that legal in nz?
What I was going to do was run a wire from the reverse light to the fog light and connect it up then replace the centre red fog light in the hatch with a clear reverse piece.
Should work shouldn't it?
Does anyone know if you can just buy a clear centre to replace the red centre for the rear light?
The Red Warrior
Yeah, that's legal in NZ. Dunno about getting the clear lens as a separate piece but you might have some luck getting an inner left light assembly that is already broken (except for the lens piece that you require) cheaply.
Nz_gti
Cheers red, yeah that's what I was thinking to
