Author Topic: Which coolant liquid to use for R32 mk4 2003?  (Read 628 times)
Offline NZBRO
« on: January 10, 2017, 02:39:51 pm »
Hi there,
Can anyone please help me with which coolant do i use for my 2003 R32 mk4
My warning light just came on today said STOP CHECK COOLANT so i stopped to check
and its below minimum level. The colour is pink.
I checked on Repco and Supercheap auto website but am unsure which one to buy.
« Last Edit: January 10, 2017, 02:43:14 pm by NZBRO »
Offline ziptie.nz
Re: Which coolant liquid to use for R32 mk4 2003?
« Reply #1 on: January 10, 2017, 02:54:42 pm »
Call this number  0800300426
The car is damned... Time to buy a Honda.
« Last Edit: January 10, 2017, 02:57:18 pm by Seaman Stains »
Offline NZBRO
« Reply #2 on: January 10, 2017, 02:57:55 pm »
I use to own a honda but it died lol
« Reply #3 on: January 10, 2017, 03:02:39 pm »
I suggest to use the genuine VW G13. Either from a dealer or Qualitat do the same thing under a different brand name which is a bit cheaper.
Offline NZBRO
« Reply #4 on: January 10, 2017, 03:14:36 pm »
Awesome thanks mate i will go to a VW dealer to get the G13.  ;)
Offline luckychum
« Reply #5 on: January 10, 2017, 10:13:21 pm »
Use G13.  But also check the car for leaks, especially around the top of the gearbox.  The leaks only get bigger with time.
2003 Bora V6 4MOTION
2001 Golf V5 Manual
« Reply #6 on: January 11, 2017, 07:14:14 am »
You best find out why the coolant level has dropped, you must have a leak somewhere.
Offline NZBRO
« Reply #7 on: January 11, 2017, 08:48:52 am »
Omg i hope theres no leaks, yes I'll definitely watch out for any leaks. Where abouts on top of the gearbox would i find a leak?
« Reply #8 on: January 11, 2017, 09:18:38 am »
If you have leak it would actually be below your intake manifold
Otherwise on the rear of the engine (passenger side) on the over run pump or water fitting on the block.
The other possibility is that it had a slight air bubble and has finally worked its way out?
Without diagnosing it myself? I'm not able to advise which one of the two they are.
But you should have a trail of dried coolant if you have a leak.
Mk3 12v VR6 Variant
