Debadging
Started by Long Black, February 02, 2017, 08:01:39 AM
Long Black
Any ideas on the best way to debadge from bodywork without marking the paint work? I am looking at changing chrome badges to black. Also, has anyone out there purchased an aftermarket grille; ie Honeycomb mesh RS style for a B8 S-line. Wanting to go black fittings on my white B8.
1999 B5 VW Passat V6 Syncro Wagon - Black...gone
2007 B7 Audi A4 S-line Avant Quattro 2.0T - Black...gone
2011 B8 Audi A4 S-line Avant Quattro 2.0T - White..Gone
2008 Mk5 VW Golf GTI - Black
2012 B8 Audi S4 Avant - Brilliant Red
gti vr6
Best way with your badges is to use a piece of fishing line fine enough to fit between the badge and the car and work it through with a sawing motion, this will cut through the glue and release the badge. Then it's just a matter of cleaning the glue off the paint work.
1986 Mk2 Scirocco
2021 T6.1 4M LWB Transporter Trendline
Quote from: Long Black on February 02, 2017, 08:01:39 AM
Plastidip is the other option with for the badges, you can spray them black without removing them.
KiwiC4S
A little heat from a hair drier helps soften the glue's hold and I've successfully pried badges off in the past doing this. "A little" is key here - don't use a heat gun.
'06 997 Carrera 4S
Long Black
Thanks for the feedback...successfully replaced silver S-line and Audi badges with black, and have installed gloss black RS grille. Hair dryer and dental floss worked a treat for me to debadge, then some Dissolve-It.
Mike1410
Quote from: gti vr6 on February 02, 2017, 09:15:58 AM
Dental floss also works. Take your time and as also posted above - it's easier if you warm the badge/glue up first with a hair dryer.
