Author Topic: Mk2 cli water inside passenger side  (Read 421 times)
Offline vwvlad
« on: May 20, 2017, 01:45:37 pm »
After a rainy day I get water on the passenger side floor , does anybody know why ? Where are the rain plugs for the mk2 possibly might be blocked ,
Offline pauldillo
Re: Mk2 cli water inside passenger side
« Reply #1 on: May 22, 2017, 11:26:26 am »
Sounds like the infamous soggy door card problem. Is the bottom of your door card wet too?
Take off the door card. There should be a sheet of plastic behind that is glued/taped to the door frame, it prevents rainwater coming into the car. It's probably missing or damaged. Seal it back up with black tape. Or if you want to rectify a poor design then try something like this: http://clubgti.com/showthread.php?115175-Is-this-the-definitive-solution-to-a-leaking-Mk2-door-membrane-skin
Offline SG
« Reply #2 on: May 22, 2017, 08:39:36 pm »
Thats a damn good option man, nice post.
If it turns out to not actually be the membranes... have a read through this.
http://www.matey-matey.com/leak_prevention.shtml
Have fun man. Here's some inspiration for ya.
