Author Topic: RS2 Head Liner  (Read 433 times)
Offline GT4GrpANZnew
RS2 Head Liner
« on: June 13, 2017, 07:33:17 pm »
Any body have any contacts for Head Liner reinstatement on RS2 ?
Yes a sun roof.
Thanks in advance
Offline spooln
  • Sciroccos come in 2 litres!
Re: RS2 Head Liner
« Reply #1 on: June 13, 2017, 07:56:14 pm »
Would be a very rare spare. Wouldnt S2 or 80 wagon be the same?
Re: RS2 Head Liner
« Reply #2 on: June 13, 2017, 08:11:15 pm »
Not black.
Just remove the hood lining and get it recovered by a auto upholsterer, best results from someone with a vacuum table
Offline snowtyres
  • 1990 urq RR, 1995 S2 Coupe
    • roof carrier systems
Re: RS2 Head Liner
« Reply #3 on: June 13, 2017, 10:27:05 pm »
I recently replaced the head lining on my S2 coupe, (this is never a problem with my 'quality built' ur quattro 20V) the foam backing breaks down after 20 years, best to have a 'quality' trimmer replace it with a material,
that is currently available, that matches the original as closely as possible.
While you are at it check the door trim material as the foam backing also beaks down at the same time.
It is possible to have the trimmer use the door trims again as this 'vinyl type' material it does not stretch, and 'balloon', like the head lining does. All he has to do is remove the old foam and replace.
Offline weta.worker
Re: RS2 Head Liner
« Reply #4 on: June 14, 2017, 08:10:04 pm »
I did this "Just remove the hood lining and get it recovered by a auto upholsterer, "
1994 RS2 GUARDS RED
2001 RS4 NOGARO BLUE
