Author Topic: Coupe quattro rebuild  (Read 3071 times)
Offline Audi do
« on: June 20, 2017, 09:33:29 pm »
In approx a month I will be taking possession of my 1986 Audi coupe quattro.
I need to make room in my garage before I do, I will be rebuilding/restoring it.
The quattro was stripped but most of the parts are still there so I have started bringing home parts, one of the biggest parts is the engine. For whatever reason the original 2.2 engine was sold and what will be replacing it is a KG 2.1 turbo engine from a Audi 200 (what I can tell).
I was the second owner so I am quite excited to have it back in my care.
The rebuild will be a long winded affair and will depend on my health (I have been diagnosed with Chronic Fatigue Syndrome) and finances, I am not very good at updating or taking photos but will do my best.
« Last Edit: June 22, 2017, 03:52:07 pm by Audi do »
Offline RobClubley
  • Audi Owner!
  • Incessant car tinkerer
Re: Coupe quattro rebuild
« Reply #1 on: June 20, 2017, 09:44:36 pm »
Wow you have your work cut out there! Please keep us up to date on progress :)
quattro project
Offline Audi do
« Reply #2 on: June 20, 2017, 10:19:28 pm »
You ever get the "I wish I had never sold that car"?, well this is it, i had thought I would never see it again and when I came across it, I promptly bought it.
I am no stranger to the spanners (have been fixing cars for most of my adult life, along with small motors, chainsaws etc).
The body is mostly rust free save for a bit by the sunroof.
Under the windscreen
And the rear of the roof and over the passenger side.
Offline RobClubley
  • Audi Owner!
« Reply #3 on: June 20, 2017, 10:25:39 pm »
They seem to be the common areas as well as boot hinges and A pillars.
I have a few coupe bits lying around. Might be able to help you out if you're missing stuff.
quattro project
Offline Audi do
« Reply #4 on: June 20, 2017, 11:06:58 pm »
Nice one Rob.
I am going to need a sunroof, smoked tail lights, head lights. Will see over the next few weeks what else I need.
The car does have rust in the A pillar but is only surface
Boot hinges seem ok.
Offline slowburn
  • how many is too many?
« Reply #5 on: June 21, 2017, 06:26:25 pm »
any shots of the engine bay?
i have a few bits kicking around that i may be able to help you with...good luck,good to see another CQ on here
85 coupe quattro
85 coupe GT
72 fiat 124 coupe
97 corolla wagon
Offline Audi do
« Reply #6 on: June 21, 2017, 08:59:26 pm »
Pm me if you like about the parts you have, cheers.
« Reply #7 on: June 21, 2017, 09:46:51 pm »
Fitting a 10v turbo from a 200 running on kjet is a real pita. Easier to ditch it in favor of efi. Ill have a look for what typ85 stuff I have left as I had a major clear out a few months a go
Offline RobClubley
  • Audi Owner!
« Reply #8 on: June 22, 2017, 10:04:19 pm »
Don't know if you're on Facebook but there's a groups called "Audi Ur Quattro GB"
Someone on there selling a sunroof for 40 quid.
Postage would add a bit though.
quattro project
Offline Audi do
« Reply #9 on: June 22, 2017, 10:20:07 pm »
Would be better than mine.....
Offline Audi do
« Reply #10 on: June 26, 2017, 05:25:15 pm »
How does one identify a quattro gearbox, I have two (possibly 3)
« Reply #11 on: June 26, 2017, 06:43:12 pm »
There will be a code on the bellhousing, will be 2 or 3 letters follwed by some numbers, the letters are the identification code
Offline Audi do
« Reply #12 on: June 26, 2017, 09:04:29 pm »
Found them
What gearboxes do I have?, ratios etc.
« Reply #13 on: June 26, 2017, 10:15:51 pm »
The AAJ is from a c3 quattro, the US is from a b2 quattro. Both are 4.11 final drive ratio.
US
1st-3.600
2nd-2.125
3rd-1.458
4th-1.071
5th-.778
final-4.11:1
AAJ
1st-3.600
2nd-2.125
3rd-1.360
4th-.967
5th-.730
Offline Audi do
« Reply #14 on: June 27, 2017, 09:31:06 am »
US
1st-3.600
2nd-2.125
3rd-1.458
4th-1.071
5th-.778
final-4.11:1
AAJ
1st-3.600
2nd-2.125
3rd-1.360
4th-.967
5th-.730
Good info, have been searching but nothing like that came up. Which is the better box?, I assume they are largely the same aside from 3rd, 4th, 5th ratios? or are there other differences?.
« Reply #15 on: June 27, 2017, 10:32:34 am »
Only difference is the ratios, identical boxes otherwise.
Offline Audi do
« Reply #16 on: July 01, 2017, 05:17:31 pm »
Who knows of a website that can translate one of these?
Offline Audidude
    • Audidude's home on the web
« Reply #17 on: July 02, 2017, 09:38:10 am »
This any use?
http://b2resource.com/optioncodes.php
Offline Audi do
« Reply #18 on: August 16, 2017, 12:05:16 pm »
What gearbox to use and which is the better box?. Are the bearings/gears the same or are they different?
What ratio box should I use?, I am tending to use the US box because I want good torque assuming it will take the power from the turbo engine?.
« Reply #19 on: August 16, 2017, 12:52:41 pm »
Use the aaj box, better ratios.
They are identical internally and are the same strength. You will not be able to break any box with a 10v
