front adjustable strut mount cut out
Started by dummer, July 06, 2017, 09:48:10 PM
dummer
Hi,
if I install adjustable strut mount, do I need to modify the strut tower (in order to tighten the camber bolt?)
Thanks
apperciate if anyone can post a pic with adjustable strut mount installed, tried goole and found nothing
Filx
I'll assume you mean adjustable strut mounts for camber/castor? In which case yes in Mk5/6s you cannot get to the (typically) 4x allen bolts to adjust the camber plate without some sort of mods to the metal work.
robh
dummer
Thanks for the answers.
Didnt read in the FAQ from IE
Do I need LVV if I cut a bigger hole in the strut tower?
If yes, I guess I'll go with 034 instead of adjustable then
