Lowering options for B7 2.0T avant Quattro
Started by Dondbg, July 11, 2017, 09:55:10 PM
Quote from: le mans on July 14, 2017, 11:10:19 AM
Cert required if less than 100mm ground clearance, or if the height is adjustable: http://www.lvvta.org.nz/documents/suplementary_information/LVVTA_LVV_Cert_Threshold.pdf
So a small drop using lowering springs should be fine.
As Le Mans pointed out,
If a structural part of the vehicle is below 100mm from the ground. Even with Lowering springs.
The vehicle would require LVV.
Dondbg
Make sense.
I'm after suspension kits with fixed hight That is not below 100mm so below doesn't apply :)
What options are avaible in Nz to acuhive like 30mm drop, I'm looking for spring + shock kit.
Thanks guys.
DTM
Just to understand what is a legal drop  and how many mm.?
I've never come across one must have a certificate if the car is lowered. I can understand that certain drops must be within certain ranges maybe where I used to come from all this doesn't exist cause no one was monitoring it or there was no legislation in place stipulating what is a safe drop and what's regarded as overboard such as bagging.
le mans
The thresholds are in the link above (steering and suspension). Anything that exceeds the threshold and has not been certified by the LVVTA should fail a wof inspection.
I can't find the link right now,
But found some H&R springs on trade me for $280-350. Again can't exactly remember price I saw.
Have a quick search.
Quote from: DTM on July 16, 2017, 04:06:45 PM
That depends on what was mentioned earlier that no structural part of the vehicle is lower than 100mm.
Each car is different.
For example, A tiguan with 300mm off the ground, could in theory be lowered as much as 200mm.
But a car that has 120mm off the ground, 20mm or less lowering kit, taking into account the spring settling height.
NZSPQ
Hi, my 2cents worth :)
https://www.kwsuspensions.com/products.html
I have KW v2's for the S5 and the Coupe - great ride.
Dondbg
I heard that if you got coilovers installed then you must get a certificate
Find hard to believe and yet and I can confirm it's true.
Anyone ?
Quote from: Dondbg on August 29, 2017, 03:31:31 PM
Anyone ?
This is correct. And you can only adjust the height +/- 5%.
These days certs are $700ish.
Dondbg
Quote from: RS ZWEI on August 29, 2017, 03:37:07 PM
Even if the ground clearance is above 100mm still cert is required !?!
This is a ripoff , WTF $700 for someone to have a look at a German certified coils and stick a plate... fffak
00quattro00
