Author Topic: Mk2 vs Rain  (Read 647 times)
Offline BCH
Mk2 vs Rain
« on: August 09, 2017, 10:19:40 am »
Hi vask - my Mk2 (KR 16v) hates the rain. It will misfire in downpours, and if left to sit in the rain it will likely not start.  Any trouble shoots?
Mk2 GTI 16v
Offline deedub
Re: Mk2 vs Rain
« Reply #1 on: August 09, 2017, 06:26:42 pm »
Dodgy coils don't like the wet. Also a missing or cracked up scuttle tray (under the bonnet vents) allows water to get allover the ECU.
Offline vdubdave
  • Straight is Easy - Corners are more FUN
Re: Mk2 vs Rain
« Reply #2 on: August 09, 2017, 08:34:20 pm »
Mine was temperamental in the wet until I replaced the HT leads with decent 8mm ones
82 GTi Cabriolet EG engine
82 GTi Pretender PG engine
Offline BCH
Re: Mk2 vs Rain
« Reply #3 on: August 10, 2017, 04:16:07 pm »
Thanks both, scuttle tray has seen better days and the coil has a few km's on it now. Will check these out.
Mk2 GTI 16v
Offline SG
Re: Mk2 vs Rain
« Reply #4 on: September 04, 2017, 06:52:41 pm »
If you've not checked already, make sure your drainage holes are clear of debris and check the ecu plug too.
Bit of lithium electrical grease on the contacts and if the ecu plug rubber sheath has seen better days wrap it in something waterproof until you can find something more suitable. I'd go over the contacts on the coil too I think...
Disconnect the battery before you do this.
My 8v used to do this in the wet until I replaced the Leads too.
I've read numerous threads about how important the earths are on old golfs, some people don't agree but I keep an eye on mine anyway.
Apologies if this is all obvious.
Offline BCH
Re: Mk2 vs Rain
« Reply #5 on: September 05, 2017, 01:03:00 pm »
Thanks SG, that's really helpful.
Mk2 GTI 16v
Offline SG
Re: Mk2 vs Rain
« Reply #6 on: September 21, 2017, 11:02:56 am »
