Author Topic: A4 B5 Quattro AEB race clutch kit  (Read 620 times)
Offline Corstang
  • A4 B5 How low can they go
« on: September 01, 2017, 08:55:10 am »
Hi there. very new here...
So I am looking for a good clutch kit/Flywheel for my Jap import A4 1996 model.
EFORTISSIMO Racing ( I emailed this company just checking before ordering, but I am getting told my 1996 if different to the 1997 model?)
 EFT STAGE 4 CLUTCH KIT+RACE FLYWHEEL 97-00 AUDI A4 QUATTRO B5 VW PASSAT 1.8T
Any help would be great
Re: A4 B5 Quattro AEB race clutch kit
« Reply #1 on: September 01, 2017, 10:09:33 am »
How much power are you running?
Offline Corstang
« Reply #2 on: September 01, 2017, 11:49:39 am »
Not much at present, just starting a bit of a project. maybe 300kw towards the end on the build though...
wanting to get away from the dual mass flywheel though.
« Reply #3 on: September 01, 2017, 12:10:27 pm »
All 1.8t take the same clutch and flywheel, there is no difference between years.
If you are going to make 300kw get a 240mm kit.
https://jhmotorsports.com/shop/catalog/jhm-lightweight-flywheel-and-clutch-combo-with-b7-rs4-pressure-plate-for-b5-b6-a4-18t-p-1231.html?cPath=0_2
Offline Corstang
« Reply #4 on: September 01, 2017, 01:05:31 pm »
Hey thanks for the information.
I didn't think there would be any difference.
Offline wilco
  • Ted the Mechanic
« Reply #5 on: September 01, 2017, 08:21:55 pm »
Buy the cheapest one around for now as if youre aiming for 300kW you need all the coin you can muster. And if its a way off yet theres no point trying to work up a Stage 4 clutch with 110kW you have now.  Waste of tech and money. Youre going to have the engine out again at least once so its not as if you wont be looking at the clutch again.
W.
Offline Corstang
« Reply #6 on: September 04, 2017, 09:06:44 am »
Thats what I was thinking... cheap clutch to start with.
Is 110kw what they came out with? had my A4 since 2005. ran a real slow time at Meremere and smoked the cltuch back then...
Only had it a week before exhaust, air box and boost was added...200 odd km later and she still goes..
« Reply #7 on: September 04, 2017, 09:31:02 am »
I think the stock air box is very good, not much point to remove unless doing MAF delete and going stand-alone ECU. AEB is 110kw stock.
Offline Corstang
« Reply #8 on: September 04, 2017, 01:18:02 pm »
goes a lot better with carbon fibre Air box plumbed from lower vent with a big pod filter
« Reply #9 on: September 04, 2017, 01:20:23 pm »
Ive got a spare aeb and brand new single mass flywheel and clutch kit for sale
Offline S1
« Reply #10 on: September 04, 2017, 05:22:43 pm »
Ive still got 460bhp on a duel mass, does  clutch dumps at Ledfoot just sweet
whats broken this week , hold on ill get my wallet
