Author Topic: A couple problems with the GTi, help needed  (Read 703 times)
Offline Jaycray NZ
« on: September 06, 2017, 11:12:59 am »
Hi everyone, a couple issues have come up recently with my car.
About 25-30% of the time, when I start her up it will stutter like it's struggling to turn over. Sometimes it's worse than others.
I've done a bit of research online and a few people said to change the spark plugs and coils so i bought a fresh pack of each....still having the problem :(
Another issue that has recently arisen is jerky DSG shifts and general acting up form the transmission.
After a cold start in the morning, it will stay in first gear until about 3k then slightly jerk into second. Jerks are a lot more noticeable when I'm going "fast" normally from 3-4th gear.
Anyway, I'm a wee bit worried at the moment but hopefully someone here can shed some light on the situation.
Thanks in advance for any replies!
James
Re: A couple problems with the GTi, help needed
« Reply #1 on: September 06, 2017, 11:52:39 am »
What mileage on the car?
Everyone will say get it scanned so if you have, or can get access to someone, with VAGCOM do a scan and see what fault codes it's throwing.
Rough running at cold start can be carbon clogged inlet, often shows as intermittent misfire fault codes on cold start.
Offline Jaycray NZ
« Reply #2 on: September 06, 2017, 12:29:23 pm »
Cheers for the reply, the cars sitting at close to 106KM.
I don't have a VCDS, but it sounds like a good investment so I'll look into getting one.
Offline Jaycray NZ
« Reply #3 on: September 07, 2017, 09:21:55 am »
Quick update - Started the car this morning and this time it was really quite bad so I've gone ahead and ordered myself a ross-tech VCDS to see whats happening.
Any other replies regarding what may be wrong is greatly appreciated! :)
« Reply #4 on: September 07, 2017, 03:07:36 pm »
Where abouts are you? One of the locals might be able to help with fault code scans.
I'm in Wellington and i have a vagcom.
MK6 GTI
B7 RS4
Offline Naekyr
« Reply #5 on: September 07, 2017, 05:12:35 pm »
otherwise supercheap will do code scans for $15
Offline Jaycray NZ
« Reply #6 on: September 07, 2017, 11:02:04 pm »
I'm in Christchurch.
Oh man I wish I knew that before spending $400 on a VCDS!
Just kidding. I'm glad I invested in one for now, and future use.
Offline Naekyr
« Reply #7 on: September 08, 2017, 01:19:09 pm »
so what codes came out?
I've got a bluetooth wireless one that works with a phone app, cost $10
Offline VW'n
« Reply #8 on: September 08, 2017, 01:24:17 pm »
Can you tell us more about your $10 Bluetooth scanner!
I'm guessing that you can only pull codes and not perform much else?
Where does one purchase said device?
87 Mk2 Golf silver (the toy)
95 mk3 gti rusty ABF (Sold)
86 Mk2 Golf red (sold)
89 Mk2 Golf blue (sold)
Offline Jaycray NZ
« Reply #9 on: September 08, 2017, 02:08:16 pm »
My scanner hasn't arrived yet as its coming from aussie, but will post what comes up on this thread when i do.
Offline Naekyr
« Reply #10 on: September 08, 2017, 05:57:36 pm »
It can pull codes, reset codes and realtime sensor data such as boost etc
https://www.alibaba.com/product-detail/2017-OBD2-OBD-II-Super-Mini_60609918905.html?spm=a2700.7724838.2017115.148.3c93b095QUjFXu
Need a phone app like this: https://play.google.com/store/apps/details?id=org.prowl.torque&hl=en
