Author Topic: Brake Pressure Sensor 1 (G201)  (Read 618 times)
Offline Darrend1980
« on: September 06, 2017, 12:51:53 pm »
Afternoon all,
Has anyone had any experience with the below VAG code?
Address 03: ABS Brakes        Labels: 1K0-614-517-MK60-F.lbl
   Part No SW: 1K0 614 517 AC    HW: 1K0 614 517 AC
   Component: ESP FRONT MK60-AT   0102
   Revision: 00H14001
   Coding: 0021122
   Shop #: WSC 00046 412 00000
   VCID: 68DF5E2B5B86005E3C3-803D
1 Fault Found:
01435 - Brake Pressure Sensor 1 (G201)
            012 - Electrical Fault in Circuit
Initially I thought the ESP light was on because of a dud ABS wheel sensor - however, this to me tells a different story.
Cheers in advance
Darren
Offline ziptie.nz
Re: Brake Pressure Sensor 1 (G201)
« Reply #1 on: September 06, 2017, 02:36:19 pm »
haha fun job changing that one... need hands that can fold back on them selves while squeezing between the Cambelt Cover and the suspension tower.
Offline Darrend1980
« Reply #2 on: September 06, 2017, 05:01:56 pm »
Awesome - thanks ranton-inc I can't wait to try this one out!!
Offline Worms
« Reply #3 on: September 06, 2017, 07:12:24 pm »
oooooh... you might find it even more annoying than that...  :-[
On a MK5 of that vintage, it's more likely that it's more major than that...
Your one will have the G201 inside the ABS module! It's almost as hard to work on, but it's also a LOT more expensive!
Oh - it's the same as the used module I have here on the shelf:
Code: [Select]
   Revision: 00H13001
   Coding: 0021190
   Shop #: WSC 01324 785 00200
   VCID: 68DF979A5BD76E61C7B-803D
No fault code found
which DOES have it in the module  :(
It's a common issue and the same design is in a lot of cars - including a bunch of jap ones. I haven't prices a new repair kit in NZ (1K0698517B), but they are US$582 from ECS in the US - whiich is annoying, because I got a BMW one for the mrs car for just over NZ$400 shipped! You have to verify it works with your module, but I'm 90% it does.
Verify it, but I suspect you'll need a module! Verify correct function of the brake light switch in measuring blocks in VCDS, and make sure the pedal isn't sticking down a bit. You can also look in the ABS measuring blocks and see what G201 is reading - it should vary with pedal pressure.
The brake light switch is a hall-effect sensor mounted on the master cylinder. (Some early MK5 based cars have a switch fitted at the pedal, like early 8P audi A3's)
From Ross-Tech VCDS Wiki:
 01435 - Brake Pressure Sensor 1 (G201): Electrical Fault in Circuit
Possible Causes
    Brake Pedal Switch (F) faulty/jammed
    Brake Pressure Sensor 1 (G201) faulty
Possible Solutions
    Check/Replace Brake Pedal Switch (F)
        See Measuring Blocks
    Check/Replace Brake Pressure Sensor 1 (G201)
        ABS Hydraulic Unit (N55) may need to replaced
        Perform Brake Pump Bleeding
        Perform Brake Pressure Sensor 1 (G201) Basic Setting
        Replace Brake Electronics Control Module (J104)
