Author Topic: High oil consumption for 2010 a4 b8  (Read 838 times)
Offline owdy
« on: September 07, 2017, 10:28:56 pm »
Hi all,
I recently bought my audi from dealer. It is a jap import.
I noticed it has high oil consumption issues. Wondering how is this issues being handled in our shore?
if there are anyone has the same experience here? Should i try ton ork with the car yard or should i work with the authorised dealer right away?
Re: High oil consumption for 2010 a4 b8
« Reply #1 on: September 08, 2017, 09:09:54 am »
You need to take it to the dealer you bought it from and give them a chance to fix it
« Reply #2 on: September 08, 2017, 09:42:25 am »
Hi all,
How much oil is it using per "x" amount of kms? And what engine is it and how many kms has the car done?
Offline owdy
« Reply #3 on: September 08, 2017, 10:39:34 am »
It is 2010 A4 avant 1.8T. Last top up the oil at 81100s and at 81590Km is already at 1/2 looking at the MMI
Also noticed that the muffler is covered with carbon and lots of stains underneath the muffler in my garage.
« Reply #4 on: September 08, 2017, 10:50:24 am »
1l over 1000km is considered normal
Offline owdy
« Reply #5 on: September 08, 2017, 11:09:27 am »
Excuse my ignorance but I thought whats considered normal is 1qtz per 1200 MILES that close to 2000 KM? Ami missing anything?
https://www.audiworld.com/how-tos/a/audi-a4-b8-information-on-the-oil-consumption-problem-421881
« Last Edit: September 08, 2017, 11:11:57 am by owdy »
Offline McDoof
« Reply #6 on: September 08, 2017, 11:09:40 am »
What???
That would mean using 15l of oil between services. I guess you would never need an actual oil change if you are replacing twice the oil volume between services.
Offline owdy
« Reply #7 on: September 09, 2017, 10:20:13 pm »
Anyone has any experience on this?
Offline Andy_007
« Reply #8 on: September 10, 2017, 06:13:18 pm »
There is a revised PCV valve that is supposed to help , but in most cases the pistons need replacing. Take it back to where you brought it. If you have Autosure or some other sort of mechanical warranty take it to a Audi dealer to get fixed.
2007 Audii A4 Quattro 3.0TDI
« Reply #9 on: September 10, 2017, 07:23:35 pm »
Yes, and owners manuals state that too.
I would not be ok with it but the dealer will point you to that.
Offline byront8
« Reply #10 on: September 14, 2017, 04:44:56 pm »
0.5l per 620 miles or 1000km is the limit to be considered normal, if you are burning more than this the car has the high oil consumption problem. the best forum for information is here: http://www.audizine.com/forum/showthread.php/383430-THE-B8-A4-Oil-Consumption-Thread
Jap import cars will not be fixed by Audi in NZ under warranty (they will do 3rd party warranty work tho)  - they sent me a massive email stating this - I had my autosure warranty cover the piston replacement - $9800 total claim amount.
Audi will insist on a service followed by a oil consumption test. Depending on how badly it fails, they will advise you of a stage 1 (PCV change) or a stage 2 (piston replacement). Bear in mind stage 1 is a temporary fix and it will eventually go bad.
Get the chain tensioner done at the same time as the engine is out of the car - costs $650 for the kit. Worth looking at is also the water pump (known failure mode) and the engine needs to be mainly out to replace this, i got them to change my PCV and DV at the same time under the warranty.
« Last Edit: September 14, 2017, 04:53:05 pm by byront8 »
« Reply #11 on: September 14, 2017, 05:01:05 pm »
The water pump on those is super expensive a well from memory.
