Author Topic: Reading Ambient Temp via OBD2  (Read 573 times)
Offline vdubdave
  • Straight is Easy - Corners are more FUN
« on: September 26, 2017, 09:27:56 pm »
I've been doing a little experimentation - mainly so I can see what effect my charge cooling ends up having on my engine intake temperature.
(With the amount of heat soak I get it sits around 60 deg C around town and 50 degC on the open road. I can get pre detonation (a misfire) when it goes above 65 deg C).
Has anyone been able to read the ambient air temp using an obd2 tool (I've tried both a OBDLinkMX via wifi and a Carista OBD2 via Bluetooth- and both either can't read PID46 or are returning a 0.
I know VW don't provide all of the SAE PIDs via the OBD2 and wondered if the ambient temp is one of the ones the don't give....
82 GTi Cabriolet EG engine
82 GTi Pretender PG engine
