Author Topic: Jacking points  (Read 605 times)
Offline Naekyr
Jacking points
« on: October 05, 2017, 07:28:16 pm »
So I've got a standard hydraulic jack and some jack stands
Problem is the jack and the stand doesn't both fit under the jacking rail at the same time
Previously I've only had to jack up the front so this hasnt been an issue but now I need all four wheels up at the same time
How do you guys do it? maybe a scissor jack will be small enough to fit the stand and jack underneath at the same time? or maybe there is another jack point under the car?
Offline HaNs
Offline dummer
Re: Jacking points
« Reply #2 on: October 06, 2017, 10:28:26 am »
for the front I jack at the beam and locate jackstand at the lower control arm rear bushes alloy
and the rear I jack the cross bar of the subframe
https://youtu.be/eCZEq7pAHUE
Re: Jacking points
« Reply #3 on: October 06, 2017, 11:35:30 am »
use a trolley jack ?
Offline Naekyr
Re: Jacking points
« Reply #4 on: October 06, 2017, 12:04:59 pm »
yeah ill need to buy a different type of jack to use that method
Offline dummer
Re: Jacking points
« Reply #5 on: October 06, 2017, 06:30:27 pm »
given he said a hydraulic jack... I presume it's either floor jack or bottle jack?
I thought you said you have a hydraulic jack...
