Author Topic: Engine Failure 2009 Model  (Read 801 times)
Offline Emile
« on: October 05, 2017, 10:08:52 pm »
Hi Guys
I have a 2009 MK6 which has had a tensioner break causing the exhaust cam to jump three teeth and bend a few valves. Long story short, Engine needs to be replaced.
New engine going on is from a 43000kms 2011 model however the mileage on mine is around 76000kms. The new engine has had a new tensioner and timing chain fitted as part of the condition of the purchase of the engine. All up setting back close to $10k with labour, fluids, etc.
Given the car is in good nick, does this pose a significant problem regarding the value of the car should I want to sell it?
Also, Anything worth selling out of the engine aside from the cams just to help me recoup costs. I am really at a loss regarding keeping it given I now know the car inside out OR selling it and trying to get some money back seeing as it is owing me around $30k and have only had it since December last year (2016). Car is a daily driver that my wife uses for work as a pharmacy sales rep so its not hammered at all.
Any thoughts, jabs, or just poking fun would be welcomed without offense.
Cheers,
2009 MK6 Golf GTI DCC
Offline Worms
Re: Engine Failure 2009 Model
« Reply #1 on: October 06, 2017, 08:04:17 am »
Should have bought a Honda???  ;)
Unfortunately, it's a common thing on those motors. Is it a 1.4? TBH, I wouldn't touch one, unless I had a plan for the engine replacement when it is required. Tourans had a version of the same engine, and I'm waiting for them to show on Trademe with poked engined or DSG's, so I can buy one, throw it all away and fit a 1.6 MPI and manual box, or another 3.2 R32 engine and manual box (like my current Touran)  >:D
You might get a few hundred dollars of parts from the engine, but you'd have to wait and see what people wanted. Don't bet on recouping much from it. Someone may want the pistons, if it's a 1.4, because they've been known to demolish them too.
The value isn't affected by the repairs really - You can say it's had a newer engine, with new chains etc, which should help with the sale... but then you're also telling people about this common problem and then they might not want your car at all then - they may look for a more reliable model! It's a selling point that the chains aren't the original, but I don't know if the tensioner design has changed significantly enough to stop the issue in the future???
Selling it isn't going to get you any money back, because you need to spend it on something else anyway.
It's a shame, because they go very well... until they go bang  :(
Offline Emile
« Reply #2 on: October 06, 2017, 08:42:10 am »
Thanks. Itís a GTI with DCC and is DSG.  Sorry , forgot to mention that minor detail.
Offline dummer
« Reply #3 on: October 06, 2017, 10:28:05 am »
Will changing the head only a bit cheaper? (I saw a invoice around 7k for bent valve replacement in dealer last time I went in for service)... but don't quote me on that :-X
« Reply #4 on: October 06, 2017, 11:31:54 am »
commiserations    :(
is the car nz new ?
will dealer/vwnz help out ?
« Last Edit: October 06, 2017, 11:34:15 am by schattenblau »
Offline Worms
« Reply #5 on: October 06, 2017, 12:14:23 pm »
Hmmm... I thought they went "bang" a lot less. Still - probably not worth flicking afterwards.
« Reply #6 on: October 06, 2017, 12:45:38 pm »
Just drive and enjoy i guess! With so many imports, the value of them has really dropped.
My GTI is a 2010 NZ new done almost 120km with regular servicing, biggest issue iíve had was a rear main engine oil leak and a dud MAF, noth replaced free of charge byVW.  Just about to sign up for another 3 year warranty and service plan as selling it would not net me much and i donít really like the mk7 GTI.
I read that putting lower fuel grade can often lead to this sort of problem.
Also being NZ new, what was the service history like?
MK6 GTI
B7 RS4
Offline Emile
« Reply #7 on: October 06, 2017, 01:46:53 pm »
JAP import. Service history since 60k has been feasibly decent from a private place in Henderson.. Previous owner may have given it a hammering which you could not really pick up from service history. VW says nothing they could do even though they did the 75k service three weeks prior. Will avoid Tristram European in future given they quoted me $11k for a new engine from Singapore excluding labour because they could not source a second Hand engine locally. Another mechanic in the shore is looking after me now and his labour is $75 per hour plus gst. Looking around 12 - 20 hours end to end hence the cost.
Offline deedub
« Reply #8 on: October 06, 2017, 02:03:03 pm »
Sorry to hear about your engine. If it were me, I'd be using it as an excuse to spend the money (and then some) on forged internals and a turbo upgrade, with the engine you have.
That's assuming your pistons have sustained damage. If not, surely just a new head would be a lot cheaper than a whole new engine...
Since it was a tensioner failure, I think fuel and service history won't be so relevant? Seems to be luck of the draw.
Offline DanZ
« Reply #9 on: October 06, 2017, 02:05:15 pm »
Is there a way to check if your tensioner has been upgraded? I'm worried now. Just had a little research, it is common problem.
« Reply #10 on: October 06, 2017, 02:16:12 pm »
Contact 80 Vert - he may be able to source a used engine for you and also install it.
MK6 GTI
B7 RS4
Offline thomas.dq
  • They call me Thomas.
« Reply #11 on: October 06, 2017, 04:25:34 pm »
Been there, done that  :-\
https://imgur.com/a/34mXZ
1997 Mk3 Golf VR6
2010 Mk6 Golf GTI
« Reply #12 on: October 06, 2017, 05:32:23 pm »
Could have done that for a LOT less than 10k, I have a couple of those engines here.
It makes no difference if NZ new or Jap and has little to nothing to do with servicing, tensioner is a crap design and pretty much a crap shoot as to when it fails.
When you replace the tensioner you MUST also replace the chain.
There's an inspection plug in the chain cover which allows you to see what version is fitted.
Id be interested in whats left of the old motor, can always use parts.
« Last Edit: October 06, 2017, 05:34:30 pm by 80 Vert »
