Author Topic: NGK Spark Plugs  (Read 636 times)
Offline Emile
NGK Spark Plugs
« on: October 12, 2017, 06:00:56 pm »
Hi Guys
Need to know if anyone knows if I can use NGK BKR7EIX Iridium IX Spark Plug in my MK6 with the red R8 coil packs.
Repco and VW tell me I should use Platinums. VW says Bosch and Repco says NGK.
Repco's recommendation is PFR7S8EG.
The BKR7EIX as far as I have researched is not gapped or they could be gapped at 0.8mm. How will I know what the right gap for the car is and given that it is a stock engine what do you guys suggest?
I will be using Castrol 5W30 Edge Titanium LL, a VW Oil Filter and this is for a replacement engine going in with 43k kms.
2009 MK6 Golf GTI DCC
Offline jasegti
Re: NGK Spark Plugs
« Reply #1 on: October 12, 2017, 07:46:41 pm »
BKR7EIX are generally gapped at 0.65 mm  :)
Re: NGK Spark Plugs
« Reply #2 on: October 14, 2017, 11:26:48 pm »
yes BKR7EIX @ 0.8 if car is tuned.
Mk3 12v VR6 Variant
Re: NGK Spark Plugs
« Reply #3 on: April 18, 2018, 04:24:18 pm »
Generally you would run a smaller plug gap if running more boost, not larger.
Combustion chamber pressure can extinguish spark if gap too large leading to pops and bangs / misfires
Stock should be 0.030 - 0.032 and 0.028 tuned (inches)
