Author Topic: A4 B5 Air com system removal  (Read 589 times)
Offline nzant008
« on: October 30, 2017, 11:19:13 pm »
Hi
Any remove the air con system from an A4 B?
I was wondering whether the aluminum pipes along the firewall are detachable or do you have to just cut them?
Offline dummer
Re: A4 B5 Air com system removal
« Reply #1 on: October 31, 2017, 12:30:16 pm »
You mean the refrigerant pipe? they just hold down by the aluminium block
Offline nzant008
« Reply #2 on: October 31, 2017, 02:57:32 pm »
Yes I canít quite see where the aluminum refrigerant pipes detachs by the firewall. Do I need to pull up the rubber boot?
Offline dummer
« Reply #3 on: October 31, 2017, 06:25:59 pm »
Offline nzant008
« Reply #4 on: November 01, 2017, 11:11:38 pm »
Brilliant
Why didn't I find that video in my search?? :o
Offline dummer
« Reply #5 on: November 02, 2017, 10:41:15 am »
wondering what are you trying to do. Delete air con just before summer? :o
Offline nzant008
« Reply #6 on: November 02, 2017, 12:06:32 pm »
I don't normally use the air con unless I am in gridlock.
I need to get rid of the ally pipes to fit the bracked to retrofit a strut brace factory strut brace.
Offline dummer
« Reply #7 on: November 02, 2017, 06:52:29 pm »
you mean http://audi-diy.blogspot.co.nz/2007/10/audi-a4-b5-installing-front-strut-tower.html
I remember people said you can lift the low pressure pipe so it sit on top of the mount(but I haven't tried)
Offline nzant008
« Reply #8 on: November 02, 2017, 10:19:08 pm »
Yup that's the conversion I want to fit.
I haven't heard you could lift the lower pipe, but I will give it a try before I remove the system.
Air con is nice to have when you need it! > ;D
