RCD330+ Firmware Upgrade to version 5314
Started by thomas.dq, January 09, 2018, 04:42:56 PM
thomas.dq
This is how to upgrade the firmware on the 187B revision of the RCD330+.
This will replace Baidu Carlife with Android Auto.
Version 5314 Upgrade:
  • Download the firmware (version 5314) and save the .tar file to the root of a USB flash drive
  • Plug into the head unit, turn on, and hold down the Setup button until the service menu is showing
  • Go into the Software Update option
  • Select the software update and follow the on screen instructions to install
  • The unit will reboot and may request an anti-theft code - enter 0000 to unlock.
When installing version 5314, if you receive the variant conflict error then:
  • Download the firmware (version 5515) and save the .tar file to the root of a USB flash drive
  • Now follow the instructions above to install firmware version 5314.
Firmware downloads - http://bit.ly/rcd330_fw
Video reference - http://bit.ly/rcd330_fw_video
Thanks to http://rcd330plus.com/ for the firmware and instructions.
2020 Suzuki V-Strom 1000
2017 Mitsubishi Outlander
2016 Nissan Leaf
1997 Mk3 Golf VR6
2010 Mk6 Golf GTI
bravo
My crngiar RCD330+ 6RD035187B HW: 534 came with firmware 5515 and appears to work fine so far.
Just FYI.
ethan_rose
Quote from: bravo on January 13, 2018, 09:13:06 AM
Just FYI.
Assuming you're using iOS, does your Siri work correctly? On mine I can't get the voice to come through regardless of what I do.  :-\
MY09 Scirocco 2.0T
thomas.dq
Just FYI.
Any issues with the fader control?
2016 Nissan Leaf
1997 Mk3 Golf VR6
2010 Mk6 Golf GTI
ethan_rose
Quote from: ethan_rose on January 17, 2018, 01:14:29 PM
Downgraded to 5314 and Siri problem solved.
MY09 Scirocco 2.0T
bravo
#5
Sorry for not replying sooner.
I have Android Auto with FW 5515 (not car life). MY09 R36
Works pretty much fine except:
Highline camera not compatible so no camera as of yet
Android Auto hangs on a semi-regular basis and I have to reboot (long press of power button). Could be a phone compatibility issue (LG G6+) as at first it wouldn't work at all until I enabled USB debugging.
Callers complain of an echo.
Steering wheel buttons don't work due to incompatible can language. I have the 8-button wheel and red MFD. Newer 12-button wheels and colour MFD apparently work ok.
Fairly often calls answer on handset or speakerphone mode not Bluetooth. Sometimes I can hit the Bluetooth button on the screen and it works, sometimes not.
Otherwise everything else is pretty good. Love google maps and OK Google. Have sideloaded AnyAutoAudio so I can stream SoundCloud and Carstream so I can stream YouTube.  Sound quality is good and fade controls work fine.
Just wish I could eliminate the bugs.
Suppose it's ok for just $400. Shame there isn't something just a bit better for under a grand. Anything that seems to work properly is a few thousand bucks.
portmanteau
Quote from: bravo on March 10, 2018, 12:20:25 AM
See new thread
