Author Topic: Can i make my DTRL’s switch off on either side when indicators are on?  (Read 448 times)
Offline Chchgti35
  • 2012 Mk6 GTi 35 edition
I note that all recently new cars with DTRL’s will block the running light on the relevant side when the indicators are switched on and then switch back on once indicator has cancelled. Is this possible to program this on Mk6 GTi Ed 35?
Offline Alfashark
Re: Can i make my DTRL’s switch off on either side when indicators are on?
« Reply #1 on: February 10, 2018, 03:22:55 pm »
Should be doable... What I'm copy and pasting below is for a Mk3 Octavia (2013-16) so I'd imagine it'd be very much the same for your Golf.
If anyone with greater knowledge wants to chime in and correct me, feel free.
Controller 09 - Central Electronics
16 - Security Access - enter 31347
10 - Adaptations
DRL led light bar dimming when indicating
(16)Leuchte2SL VLB10-Lichtfunktion G 2 from "not active" to "Blinken links aktiv beide Phasen"
(18)Leuchte2SL VLB10-Dimmwert GH 2 from “0” to “35” (20 or less will disable the light bar during indicating) Mine is set to 30
(19)Leuchte2SL VLB10-Dimming Direction GH 2 from "maximise" to "minimize"
(16)Leuchte3SL VRB21-Lichtfunktion G 3 auf "not active" to "Blinken rechts aktiv beide Phasen"
(18)Leuchte3SL VRB21-Dimmwert GH 3 from “0” to “35” (20 or less will disable the light bar during indicating) Mine is set to 30
(19)Leuchte3SL VRB21-Dimming Direction GH 3 from "maximise" to "minimize"
Left and right sides obviously.
'14 Octavia RS TDI
'06 Fabia VRS
'93 CitiGolf 1.6
Offline Chchgti35
« Reply #2 on: February 12, 2018, 05:35:19 pm »
Many thanks,
Offline ERRRNO
  • ERRRNO
im coming to chch on the easter weekend and will be able to do this for you. flick me a message if youre keen
Black 3door Mk4 TDI - current project
Tornado Red Mk5 2.0 TFSI Variant (300hp)
White Mk6 GTI DSG - god damn lemon
