Author Topic: Urquattro clutch issue.  (Read 512 times)
Offline wolfgang
« on: March 08, 2018, 07:40:38 pm »
Hi there, I am after a piece of advise.
The hose that is conecting the clutch fluid reservoir and cylinder on my 85 urquattro is sweating.
It looks like the reservoir and hose have been replaced in the past and either it is deteriorating or the wrong material, possibly they used fuelhose.
Nobody seems to sell this type of hose by the meter and i was wondering if anybody got an idea what to use and where to find it.
Looking under the dash i really want to do this job only once.
Any help is appreciated, cheers.
1985 Audi urquattro
1980 VW Scirocco S
1987 VW Scirocco Scala
1967 Dodge Coronet
1984 Chevy Corvette
Offline John Stone
Re: Urquattro clutch issue.
« Reply #1 on: March 09, 2018, 06:44:15 am »
If you want any correct part Pete Reeve in the UK is a safe bet = quattrocorner@btconnect.com
He's a good fella
86 WR
04 A3
05 V50T5
« Reply #2 on: March 09, 2018, 07:02:37 am »
Wurth make a blue hose specific for brake fluid. You could try Qualitat as I'm sure they stock it.
Offline wolfgang
« Reply #3 on: March 09, 2018, 07:55:43 am »
Thanks for the advise, i will check them out.
1985 Audi urquattro
1980 VW Scirocco S
1967 Dodge Coronet
1984 Chevy Corvette
Offline 90_B2 Quattro
« Reply #4 on: March 09, 2018, 11:45:26 am »
034 motorsport in the USA make a braided hose for the clutch reservoir to master cylinder.
Offline RobClubley
  • Audi Owner!
  • Incessant car tinkerer
quattro project
Offline Horch
  • Audi quattro 10v MTM
  • Favourite pizza - quattro
« Reply #6 on: March 11, 2018, 07:01:22 pm »
Did you find a hose solution ?
The original hose part number for clutch reservoir to master cylinder to suit rhd models is...
N 020 2811
The catch is it comes in 5 metre rolls under this part number. Rhd models require 320mm only.
MB urquattro
MB R107
DKW RT250
Offline wolfgang
« Reply #7 on: March 12, 2018, 09:07:47 pm »
Thanks for the part number but i got lucky with a mate who gave me some off cut from a job he did.
I am going to buy an original clutch reservoir from quattro corner and make it look factory correct again.
It looks like one of the previous owner had some major fluid leaks, as a large patch of sealer under the reservoir had come loose and  I peeled it of in big chunks. At least the metal underneath is nice and clean.
1985 Audi urquattro
1980 VW Scirocco S
1967 Dodge Coronet
1984 Chevy Corvette
