New R MK6 ownwer - I have a few questions
Started by Tri, March 15, 2018, 06:52:37 PM
Tri
Just got it 5 days ago. Previous owner included a new RCD330, new cambelt and water pump replacements for me. Did it yesterday and got it back today. Issues are: after replaced the belt, my car is jumping the RPM when starts. It jumps from 800-1300. Back and forth for a minute or so before back to being stable at 800. The car seems to deive fine. Never had this before the belt was replaced tho. Any idea?
Used to have reversed camera with the old RSN510, but dont have with this new RCD330 anymore. How to know if it is a 330 or 330Plus? I heard the plus can connect with reverse cam. Any advices?
I also heard and read about VAGCOM. Anything good code/mod I need to get, or nah?
The Red Warrior
Can't shed any light on the revs/engine side sorry.
As for RCD330, the RCD330G has a single CD player and a smaller screen. The RCD330 Plus has no CD player but has a larger screen. You can check which version you have by pressing and holding the settings or set up button.
I don't know of anyone who has got the OEM reverse camera working with the RCD330 (either version).
Just google vcds/vagcom changes for mk6 golf r and see what you want.
ERRRNO
Where are you located mate? If Auckland or Christchurch then I may be able to help you with VAGCOM (saves you from forking out the dosh)
Black 3door Mk4 TDI - Elite Motorsport Hyper miler
Tornado Red Mk5 2.0 TFSI Variant - Elite Motorsport Stage 2
White Mk6 GTI DSG - Elite Motorsport Stage 1
I'd say they put cambelt on wrong. Can easily be checked with diagnostic tools.
Otherwise you have a fairly large air leak in the cars intercooler system.
Check the vacuum pipe from the vacuum pump to the inlet manifold. These get brittle and split. Very common.
Tri
Thanks guys. No vacuum leak, air sensor is OK. Issue was with turbo seal having a crack and leak air. Took looong time to find out but only an hour to and half to fix. All back to normal.
Also, tried the Sport drive mode today, not the S mode, car suspension are quite stiff and can feel a lot of road-vibration on the motorway. Is this quite normal?
ERRRNO
Yeah its designed to stiffen up the suspension in the sport mode to decrease body roll etc.
slowmo
Yup that?s the DCC ?Sport? setting.
It does somethingg with the steering as well i think.
Quote from: Tri on March 21, 2018, 07:39:24 AM
Entirely Normal, I actually never use that feature due to it's stiffness.
At least on the mk6 gti? The stiffness was still pretty good.
The R36 Passat Sport DCC suspension settings is very much the same harshness.
Tri
Thanks guys. Love your helps and info sharing!
Tri
Another question and much appreciate if anyone can help me. I tried and compare different DCC modes for a week to make sure I do not put too much of my perception. But I think the sport DCC definitely gives the car a louder exhaust sound and accelerate faster than comfort and normal modes.
I thought DCC only changes the suspension and steering wheel, but nothing else?
Quote from: Tri on April 06, 2018, 11:54:45 AM
It changes the throttle mapping too. Nothing about the exhaust however.
This is why, when I advise customers to install the DCC delete kit when they install coil over suspension?
These are all the functions you loose, if you do not.
When you get a chance. pop pass and take a gander at my R. I'll even take you out on a test drive.
