Author Topic: Diagnostics Scan in Wellington  (Read 406 times)
Offline NicB83
« on: May 07, 2018, 11:41:02 am »
Hey all,
Can anyone recommend a good place in Wellington to have my 2007 MK5 GTI scanned? The headlight warning issue still persists and the headlight now only works intermittently along with the park light. Turns out the previous owner replaced the light himself after having the same issues but clearly the replacement hasnt worked. Would like to get it looked at by someone who knows what they are doing.
Cheers,
Nic.
Get In, Shut Up and Hang On! ;)
Offline thomas.dq
  • They call me Thomas.
Re: Diagnostics Scan in Wellington
« Reply #1 on: May 07, 2018, 01:27:23 pm »
I can plug in and see what shows up. I'm located in Porirua.
Jay (slowmo) has VCDS too. He is in the Hutt if you are out that way.
Otherwise I recommend Powerhaus on Tinakori Road - http://powerhaus.net.nz/
1997 Mk3 Golf VR6
2010 Mk6 Golf GTI
Online slowmo
« Reply #2 on: May 07, 2018, 01:45:17 pm »
I can help if needed, just flick me a PM.
MK6 GTI
B7 RS4
Offline NicB83
« Reply #3 on: May 07, 2018, 01:55:13 pm »
Im currently out in JVille. I spend half my time there and the other half in the Hutt. I will flick you a PM :)
Cheers!
Offline NZGTI
« Reply #4 on: January 02, 2019, 07:22:23 am »
Hi There Slowmo, I'm In Lower Hutt...  2007 Touran has developed an issue with Brake Warning light.  If you are able could I get you to Scan it for me?
I'd actually be ken to get a Scanner also....
Cheers......Warrick
2007 Touran
2003 Passat v5...gone
1999 Golf GTi...gone
1990 Corrado x2...gone
1984 Golf GTi...gone
