Author Topic: Porsche 964 1990 C4 rebuild  (Read 26003 times)
Re: Porsche 964 1990 C4 rebuild
« Reply #20 on: November 26, 2018, 03:39:12 pm »
production numbers from porsche
https://newsroom.porsche.com/default/en/products/porsche-one-millionth-911-milestone-seven-generations-13735.html
original 81,100
g-series 198,414
964 74,008
993 67,535
996 179,163
997 215,092
991 to end of the 2016 model year: 152,659
john;
any plans to upgrade the 964 headlights ?
« Last Edit: November 26, 2018, 03:46:15 pm by schattenblau »
Offline NasTnaS
  • Live and Learn.....
« Reply #21 on: November 27, 2018, 05:36:47 am »
good plan John.  ;)
...Nigel Aston
1971 Porsche 911T
1989 Peugeot 205 GTI 1.9
2009 Renault Megane R26
« Reply #22 on: November 30, 2018, 08:51:57 am »
I actually brought with me MK6 GTD and MK7 GTD fabric but decided now to use the MK7 material pictured on the right.
So, plans thus far are make HID headlights, custom 17" Fuchs wheels (rears completed), big brakes and custom interior / seats
Engine going back together stock displacement but with aftermarket cams, intake and will be run on much more modern ECU.
« Last Edit: November 30, 2018, 08:54:26 am by 80 Vert »
« Reply #23 on: November 30, 2018, 09:34:18 am »
Motronic or something else in mind, John?
« Reply #24 on: November 30, 2018, 11:19:50 am »
Im thinking MoTeC currently but there's literally soo many options these days.
« Reply #25 on: June 07, 2020, 10:02:49 am »
All good things take time, lots of distractions have come and gone but here we are with another PORSCHE update post YES!!!
I measured the case tunnels with a bore gauge, was able to tighten clearances on a couple so everything looks extremely good, crank measured like new so that didn't need anything but a clean.
Replaced the rod bolts with ARP which meant re sizing the big ends so I thought I might was well do the small end bushes as well, all new bearings through out.
Bolting the rods back on I had 2 that were too tight, in the end it came down to 4 bearing shells being slightly tighter than the others in the packet.
I ended up ordering 4 shells from Porsche since they're sold individually. Problem solved.
« Reply #26 on: June 07, 2020, 10:21:34 am »
Other than organising a few things that's where things got left till yesterday morning, I headed over to my friends place for an early start to assemble the cases.
We checked the oil sprayers in the case first before dropping in the oil pump and IMS with new timing chains.
Crank was assembled ready to go so that was dropped in next.
Double check we had all bearings, seals, chains etc etc and laid out all of the through bolts with their o rings as you only supposedly have 40 mins to bolt the sucker together before the case sealant goes off.
All went like clockwork, torqued the 11 through bolts first and the perimeter bolts after that.
From this point I've got the cylinders and heads soaking in degreaser, Ill strip the heads next and figure out what to do with those. Need to also make a decision on what to do about cams as im wanting to extract more power from this thing.
« Reply #27 on: June 08, 2020, 04:09:13 am »
It's always nice to see some progress 8)
Looking forward to seeing the next steps...
Offline NasTnaS
« Reply #28 on: June 10, 2020, 06:16:32 am »
Nice John!!! I hope you’re going high stack ITBS!!
https://photos.app.goo.gl/BnNzjQiB7TpYvFjt6
...Nigel Aston
1971 Porsche 911T
« Reply #29 on: June 10, 2020, 08:18:58 pm »
Not sure yet Nige,  spoke to a guy today with a dyno and formulated a plan.
He's going to be flowing my heads and doing other mods, going aftermarket ECU eliminating Motronic and going coil on plug getting rid of twin dizzys and leads.
Probably running RS cams and so aiming conservative 300-310hp
Offline NasTnaS
« Reply #30 on: June 11, 2020, 10:27:40 am »
Jenveys mate!!!! damn yeah!
...Nigel Aston
1971 Porsche 911T
« Reply #31 on: June 11, 2020, 08:13:18 pm »
No, that's just a rip off like many other Porsche parts with their 1000% Porsche tax.
If I do ITBs I'll put my own set together for a fraction of any kit out there.
It's all about building rather than just buying
« Reply #32 on: June 11, 2020, 08:31:28 pm »
Really looking forward to this coming together.
Offline robh
« Reply #33 on: June 12, 2020, 09:14:39 am »
I think Motec very over rated these days, so many other quality options out there.
Link gear is awesome and plenty of NZ tuners comfortable working with them.
ECUMaster Black ECU's look to be really establishing themselves in the market now.
Offline NasTnaS
« Reply #34 on: June 15, 2020, 07:05:26 am »
Woah! I completely disagree with your "rip off" term John. R&D comes at a price, and these guys have been doing ITBs since forever! I suppose its overkill for your project hence you not seeing value.
Jenvey are born from motorsport and they have pedigree.
https://www.jenvey.co.uk/about/#a-little-bit-of-history
When I did my ITBs project on my mk2 back in the day, I used GSXR ITBs which were great fun, however since the size/stack length was'nt ideal it took some time to tune them. In the end I tuned it on Alpha N however I think speed density with a map sensor per cylinder would be ideal. You need to get the 6 map sensors to only send the lowest single value to the ECU and not average them. winning!
...Nigel Aston
1971 Porsche 911T
« Reply #35 on: June 17, 2020, 05:15:21 pm »
R&D certainly does cost but at 7k plus shipping and gst I don't see the justification, certainly not for me anyway.
I would sooner put a GT3 intake on over ITBs, consensus seems to say ITBs loose torque low down also.
Have you bought some Jenveys?
« Last Edit: June 17, 2020, 05:18:54 pm by 80 Vert »
Offline Gordo
« Reply #36 on: July 06, 2020, 08:26:43 pm »
I have some, but not on a Porsche - they're a nice bit of kit.
$7k seems rather exorbitant for bare bodies - is that a full kit with ECU, fuel pressure regulator, etc. included? The bodies themselves are no-where near that - https://store.jenvey.co.uk/throttle-body-kits/porsche-engine - but then you do have the management, filters, etc. to sort out.
« Reply #37 on: July 29, 2020, 02:51:21 pm »
Not good news for the pistons and cylinders, 0.002" larger than what Porsche says is allowable.
Probably be fine in all reality for the limited use this is going to see but in the interests of doing things properly a new set is going to be ordered.
Comes at a cost though, almost 10K but the upside is I'll be going from 3.6L to now 3.8L and also eliminating the factory early 964 design flaw leak issue between head and cylinder.
Heads are under way, new valves, guides, springs, retainers, keepers etc. They will also be flycut to suit the new style cylinders.
New valves have smaller stems and are lighter weight.
« Reply #38 on: July 29, 2020, 06:32:20 pm »
3.8 RS     ;D
Offline NasTnaS
« Reply #39 on: July 30, 2020, 07:22:52 am »
damn! the 3.6 is already quite torquey so this bump up should be really good. Which P&Cs are you going with and any interesting coating?
Sorry to hijack this thread but its quite fitting. My 2.2T with the high comp pistons, wilder cams and ported heads is almost at 100bhp/liter, it made 170bhp at the wheels and still climbing but hit limiter at 6k. I'd like to get a 8k rotor limit and see how she goes....
...Nigel Aston
1971 Porsche 911T
