Author Topic: DSG oil/filter service  (Read 4583 times)
Offline flying_sandman
« on: May 29, 2018, 02:59:29 pm »
Wondering if anyone can recommend a trustworthy garage that can do this particular service?  Auckland area.  Cheers.
______________________
2009 VW GOLF GTi (Pirelli)
Offline Lino_GTi
Re: DSG oil/filter service
« Reply #1 on: June 07, 2018, 07:57:44 am »
hey have you found someone to do this for you ?
I know a guy from HomeTune that is good and reliable and he can do that for you.. and he will come to you.
« Reply #2 on: June 07, 2018, 10:37:43 am »
It might help advising us your location and distance willing to travel?
If you get stuck, I'm able to assist with the DSG servicing
Offline benckj
  • New TT Owner
« Reply #3 on: June 19, 2018, 04:15:28 pm »
Caution thread jacked here.
DSG Tran fluid other than Audi?  Just checked with Repco and they list the Penrite FS fluid for this box. Yay or Nay?
2004-Audi TT 3.2l Quattro
Mods underway!
Offline deedub
« Reply #4 on: June 19, 2018, 05:03:39 pm »
I haven't used Penrite but I use Motul for my R36 DSG with zero issues.
Offline heylinb4nz
« Reply #5 on: June 20, 2018, 03:12:18 pm »
Mine came with some red fluid from Singapore (cant remember the brand) i'm sure it meets some spec, but I swapped it out for piece of mind (Pentosin \ Genuine Audi only). The cost to fix a DSG is just too high to quibble over $150-250 difference in fluid costs.
Offline benckj
  • New TT Owner
« Reply #6 on: June 20, 2018, 07:14:04 pm »
My take on aftermarket fluids is not about cost savings but using a better product. Why put the same fluid the manufacture created 15 years ago when the technology has moved by leaps and bounds. Maybe there wouldnít be any DSG issues if good synthetic lubrication was used. Think about your motor oil and what you use now.
Jim
Mods underway!
Offline Naekyr
« Reply #7 on: June 20, 2018, 08:23:08 pm »
I just use dealer fluids
If you're gonna go aftermarket then it needs to be a better product, otherwise its all about the price - however as a consumer I find it difficult to find test results to prove that aftermarket stuff is any better
I mean look how difficult it is to just find test results of different engine oils, these companies try to hide everything
Offline benckj
  • New TT Owner
« Reply #8 on: June 20, 2018, 08:27:34 pm »
Well thatís why I am asking here for advice. For all I know there is a better alternative than what manufacture to offer. User recommendations have more weight than anything.
Mods underway!
Offline deedub
« Reply #9 on: June 20, 2018, 08:37:25 pm »
It is about price. Why pay double for something that is no better?
Dealer oils will just be purchased from a supplier meeting a certain spec. Well known and trusted brands like LiquiMoly and Motul manufacture to the same specs (or buy from a supplier who does).
You are right, there are pages of threads on the internet dedicated to arguing which is better than the other. Some have higher flash points, etc etc. I doubt most will ever be able to detect the difference, in performance or gearbox wear.
I was advised to use Motul by a specialist who works on many cars including lots of racecars and knows his stuff - far more experience than I will ever have - so I trusted him and saved enough cash to buy some diff oil as well.
Offline benckj
  • New TT Owner
« Reply #10 on: June 21, 2018, 06:30:56 am »
The reason I asked about Penrite FS is that I run it in my Mitsi 4wd and it performs better than the Ďspecialí fluid supplied through dealership. Yes it is less expensive but I use as in my opinion itís better. By saving a little money I can change more often and do a trans flush to get as much out of TC as possible. Not sure what the DSG trans is like by on my Mitsi I'm lucky to get 1/2 the capacity out by a simple drain & flush.
BTW being less expensive is not just pocket change. Gunuine Mitsi fluid would cost over $200/10 litres where Penrite is under $100 for same. Looking at doing maintenance in Spring so have some time to research.
Just for reference this is the oil which I was looking at;
https://www.penriteoil.com.au/products/dct-fluid-full-syn
« Last Edit: June 21, 2018, 11:47:17 am by benckj »
Mods underway!
Offline Naekyr
« Reply #11 on: June 21, 2018, 06:41:06 pm »
Whats the price? DSG oil can be up to $50 per litre from the dealer
Offline benckj
  • New TT Owner
« Reply #12 on: June 21, 2018, 07:46:50 pm »
Iím having trouble matching the OZ product with NZ but when I stopped in Repco the Penrite FS was $67/4litres.  I bought same product on sale for $44 last summer. One benifit is thatís itís off the self and no transport or other costs incurred.
Mods underway!
Offline benckj
  • New TT Owner
« Reply #13 on: June 25, 2018, 10:59:15 am »
After spending some time looking over car on weekend I ordered some parts through RockAuto.  Plugs, filters & brake pads.  Grabbed an auto trans filter so I can fly with aftermarket DSG fluid when I need to.   Will order the Haldex fluid & filter separately once I work out if its been changed already.
Mods underway!
Offline benckj
  • New TT Owner
« Reply #14 on: June 27, 2018, 11:33:35 am »
Doing a little more research on this and the VW boys over in OZ use Penrite for their DSG's. Seems they rate it very high and trans operate better than OEM Swag fluid. Will run with this when I do mine except I need to verify if the DCT FS is the same as fluid we get in NZ as its a different name. Waiting on filters, etc to arrive from States
http://www.vwgolf.net.au/showthread.php?25928-Penrite-DCT-DSG-fluid-Anyone-tried-it
https://penriteoil.com.au/products/dct-fluid-full-syn
Mods underway!
Offline benckj
  • New TT Owner
« Reply #15 on: June 27, 2018, 01:08:22 pm »
Reply back from Penrite on correct fluid.
Quote
Good morning Jim,
The only product we have suitable for the DSG in your Audi TT is the DCT Fluid. This product is available for purchase in NZ.
It is a product that Supercheap stock in their DC, alternatively we do keep the product in our Christchurch warehouse so you could order the product from your local Repco store.
The part number you will need to give the store is DCTF004, this is the part number for the 4 litre.
I hope this helps.
Kind regards,
Rebecca Stephens
Technical Support
Penrite Oil Company
T 1300 PENRITE (1300 736 748) | F +61 3 9801 0977 | lubetech@penriteoil.com.au
Proudly Australian Made & Owned Since 1926
Checked at SC and price is $97/4 litres but I will wait until it comes on sale. Haven't seen it advertised at Repco but might be something they stock in the future.
Mods underway!
Offline benckj
  • New TT Owner
« Reply #16 on: July 16, 2018, 02:20:19 pm »
Supercheap has 25% off all products today only. Snagged 2 x 4 litre oil packs of DCT FS for around $150 delivered. Donít usually see this stuff on sale so worth the expense to get today. Just enter Save 25 at checkout.
Mods underway!
Offline benckj
  • New TT Owner
« Reply #17 on: July 20, 2018, 08:12:03 am »
Just for information I found out the DSG had a mod with replacement of riser pipe within gearbox. This is removed when changing oil but a new longer (blue) one installed. This will raise the gearbox level by 6mm or 1/2 litre or so in box. Apparently, the older models  (ie pre 2004) initially had an issue with low levels so this was raised to compensate. Not sure if this relates to Mechtronic fails.
Glad I found this info in the UK TT forum as I can get all my bits in order before changing oil. Link below to the thread with methods & pics included. Planning to pull my drain plug, check filler adaptor fitting and colour of riser pipe. Once I know what I have I'll change the oil and filter in box.
https://www.ttforum.co.uk/forum/viewtopic.php?f=2&t=1843181
« Last Edit: July 20, 2018, 11:54:48 am by benckj »
Mods underway!
Offline The Red Warrior
« Reply #18 on: July 20, 2018, 08:57:15 pm »
Ended up reading that whole thread (despite not knowing anyone who owns a TT or expecting to ever own one myself). They are a bunch of helpful individuals without sounding all high and mighty about it.
Offline benckj
  • New TT Owner
« Reply #19 on: July 21, 2018, 07:21:35 am »
Have found most of the people on that forum very helpful. There are a couple tossers but not many. At least that site is very active so there are quick and accurate replies to any questions.
Mods underway!
