005425 code on mk5 gti
Started by pooek9, June 09, 2018, 04:07:40 PM
pooek9
I have got a 005425 code which seems to be a Camshaft Timing Adjustment: Open Circuit
Possible symptoms
faultyWiring and/or Connector(s) from/to Camshaft Adjustment Valve (N205) faultyCamshaft Adjustment Valve (N205) faultyPossible SolutionsCheck Fuse(s)Check Wiring and/or Connector(s) from/to Camshaft Adjustment Valve (N205)Check/Replace Camshaft Adjustment Valve (N205)
Anyone had this problem and what did it end up being?
Check the sensor itself for a broken connector.
pooek9
Thanks vert. I'll check that out
