2005 A3 3.2 fuel type
Started by 3.2, July 06, 2018, 11:17:21 PM
3.2
Hi,
Anyone know if you can run 91 fuel in the 2005 A3 3.2 quattro? I dont have a car manual.
RobClubley
My 2006 A4 3.2 quattro runs fine on 91.
davestokes
I had a 2004 A3 3.2 and it said 95/98 inside the petrol flap. So I did that
Worms
The 3.2 VR6 is fitted to the A3 3.2 - same as the R32 Golf. They run quite high compression.
VW recommends 98, but 95 is OK (with reduced output).
They like 98. It'll run on 95.
I could hear mine pinking, while it adjusted down to 95, retarding the timing and reducing torque at low revs.
The economy seems worse too.
I doubt it'll much like 91 at all - it'll probably have to retard the timing so much, that the economy will suffer badly, cost more than 95 would with it's improved economy.
Naekyr
Quote from: RobClubley on July 07, 2018, 07:54:14 AM
I'm not sure if you're serious
